Did they just all go out at once?Help! My Hazard light button, Rear Air, Window Defrost, Side mirror defrost buttons do not illuminate. All the other buttons do. Is there a fuse I can check or is it the light burned out? if so, am I able to replace them?
Yeah most if not all bulbs usually don't have part numbers, just need to find the type of bulb it is.There really ain't a part number for these bulbs, eh? Poking through PartSouq schematic diagrams and finding nothing for these. Sounds like an annoying deep dive to get them back on too.
Sadly no P/N for those. A close match to that bulb is a #7152 T1 5V bulb. I say close because it’s a hair brighter than the other green lamps. It could also be a #680 bulb. Even though there are only 3 active buttons you need 4 bulbs for the board.
You have to pull that sub assembly off the tape deck portion of the Infotainment unit, then disassemble it further to remove the tiny bulb sockets. Then you remove the green bulb caps and unwind the wire leads from the sockets.
Replace with new bulbs, trim wire leads, install caps, slide sockets back on, then reassemble the button sub-assembly, etc/etc.
I can confirm it is a #680 bulb like I mentioned above. The brightness is a perfect match to the other infotainment bulbs and the rubber caps fit perfect.
These bulbs behind the 3 buttons are not sold separately by Toyota, but can easily be replaced with some patience.
Thanks for the tip on the links. I should update to something more reliable.The old links are no longer working, but I found this on the rainforest store.
Did you use these just for those buttons (mirror defrost, rear ac, defrost) or were they also used anywhere else?
I have not compared yet, but I bet the #680 bulb would work for the other socketed bulbs in the dash/console switches. Namely: heated seats, rear windows, pwr/2nd switch, ahc switch.
When I get a little time to compare bulbs I can build a list. I have a pile of the little round sockets from burnt bulbs, as well as brand new pieces from Mr T.
Watch out. I might write another Christmas song as I build it.You'd be the belle of the ball if you put together a piece by piece shopping list. I'd buy you a beer!
