well, we are planning on a road trip out to CA and wouldn't you know it, i somehow broke my front diff. Here's what I did. I pulled up on a snowy (packed) side by the sidewalk across from sons school. When I came back out was unable to back out of my spot. So I engaged center diff and tried again. started rocking it back and forth but still not able to get out. Put it in 4 Low and started working steering wheel left to right, heard a loud crack and was not able to get out. Someone with shovel helped lended a hand. Then guy with jeep tow strapped me out. Went to drive away and heard and felt clacking noise every couple feet. It would shake the whole truck! Disengaged center dif and 4 low and pulled it over to get a tow.
Shop showed me the stripped teeth on my ring gear! 7 or 8. NOW the deal is this is not an easy fix. Dealer asked me to pay 1100 for Ring and Pinion for the 430 (43 teeth) set up. What I learned is the 98 year has a weak front diff. With only 4 spider pinion gears. they call it a 2 pin diff. The smartest replacement was for me to buy from JustDifferentials.net a 4 pin, more durable new front dif-6 spider gears still a 430 ratio. $1179. Part came in a couple days and the diff is being intstalled today or tomow. I called fron the US to Australia looking for a less expensive Ring and pinion, but this part is just not available anymore- Justdiff did have it for about $750 but I'd still need a few spider gears which would be a couple hundred at least and in the end I'd still only have a 2 pin diff.
Learned my lesson to not mess about with 4 low in the snow!
MORE INFO:
when i engaged 4 low i pulled as far forward as i could, then stood on the brake, went to reverse and hit it pretty hard, thats when it broke. i do believe my front left wheel must have grabbed some traction and sent too much torque down the line. I also feel that turning the steering wheel while doing this was not a good idea and must have contributed to the break. 155,000 + miles on it though.
MORE INFO:
