Update for the day.
Drove to work and back. On the way back, my temp gauge rose up past 3/4 and barely touched the red line while sitting in heavy traffic on the freeway. It dropped back down after ~30 seconds, but I am extremely worried. The engine doesn't seem to be running as smooth as last week. I won't be driving it the rest of the week.
Yeah, stay out of the red. Probably best to keep it out of traffic until you diagnose the problem and get it fixed. The system simply won't cool properly if it can't pressurize, which is what these symptoms all point to.
Is there a way for me to check and see if the PO used some sort of stop leak? How would I check for that?
You'll often see evidence of stopleak in the coolant, but you''ve been through so much that may not show. Obviously, if it was used, it's not working for this issue.
Also, how do I check for a clogged/gunky radiator? I will need to search the forum for that tonight.
I think I will pull the #6 plug tonight for a visual inspection. Not likely to get much under vehicle time with the cleaning and subsequent rinsing, as that will be dripping off for a bit.
You'll find areas that are clogged are cool, even to the touch. Obviously don't stick your hand in with the fan blades spinning, but shut down and feel around. This is one place where one of those non-contact thermometers works well to check different places on the radiator to see if the temps across it are even or all over the place, which would indicate clogging.
That said, overheating from clogging is usually a separate issue from overheating from failure to pressurize because the system doesn't seal. So you'll want to track the leak down regardless. Get it fixed and then see how things work. Our truck got a new radiator last fall because of age-related clogging. If you've still got the original radiator, probably time to think about doing that R&R anyway.
and then removing spark plugs.
