burning brakes
Oregon
Website
www.brian894x4.com
Looks like I pushed my brakes too hard today going up and down the logging roads. It really stunk bad coming down one hill, but the thing is I barely used the brakes. I'm a firm believer and active practicer of using the engine and tranny to brake going down hills, but I still needed some extra help with the brakes and despite it not really being that long or steep, I apparently overheated the brakes, based on the very noticable burning brake smell.
I noticed later in the day on a very short hill, with minimal braking, the same smell, but not as bad. I'm not sure if this is normal or not...never noticed it before, even on steeper grades and longer braking periods, but I'm wondering if slotted or drilled rotors would make any difference?
Right now the rotors are several years old, installed by the PO, but don't appear to be OEM. The pads are OEM 80 series that I installed last year, less than 5000-10000 miles ago.
So, I'm thinking of swapping rotors and I've read thread after thread about the pros and cons of the slotted/drilled brake rotors. Concensous seems to be that if you don't race, why bother. But what about this situation, where you use them to go down long hills.....would slotted or drilled rotors make an improvement?
By the way, brake feel did not change or degrade at the time of the burning smell, but they were clearly overheated for some reason. Maybe the rears aren't doing their fair share of braking. I've tried to adjust to account for the lift, but could be that they are still out of ajustment.
Do new rotors and swap to the 100 series pads at the same time. I wheel all the time and never have had a burning smell.
The 100 pads will last longer and provide a larger grip area. You don't need the shims with them
You only want to swap to these pads when installing a new rotor based on wear patterns of the older pads.
I've noticed a few times with heavy loads (or towing) exactly what you describes to me can happen.
If you're consistantly braking a lot, even if it's not all at once, you can really heat up those pads. Even with light braking for extended periods of time can get them quite warm.
After really heating them up I'll notice the burning smell a few times when I need to brake after that. I've always thought that there's probably just some brake residue that's burning off from the previous hard brake. Braking once or twice, and the smell is gone.
The pads are actually fairly small for a 5,500 lb vehicle (stock). I do plan on going to the 100 series pads as it's easy, probably when I do my front end service. I'll probably look at a way to shove on bigger calipers/pads down the road, especially for the :princess: truck as we use hers for towing.
Incidentally where were you running around logging roads at?
Looks like I pushed my brakes too hard today going up and down the logging roads. It really stunk bad coming down one hill, but the thing is I barely used the brakes. I'm a firm believer and active practicer of using the engine and tranny to brake going down hills, but I still needed some extra help with the brakes and despite it not really being that long or steep, I apparently overheated the brakes, based on the very noticable burning brake smell...
Sounds like “green pads” that were never properly bedded? Bedding them does two things; transfers an even coating of pad material to the rotor and burns off excess resins in the pad, cures them. This process involves smell and smoke, it improves the braking performance and life. If the pads still have the excess resins (green pads) it’s easy to smoke them, this won’t hurt them, your just basically doing a delayed bedding.
Long down hills with little/no traffic are great places to bed pads. During the bedding process it’s critical that you don’t stop, so on a down hill, drag the brakes for a second to warm them, get into the brakes hard without stopping, resume normal speed, repeat a couple of times, then continue driving to allow them to cool while rolling. This process will often cure brake judder, if it has come on recently.
A good read on bedding;
StopTech : Balanced Brake Upgrades
If you had overheated them you should have seen brake fade, reduced performance and changed the rotors color, most often purple. Brakes work by turning motion into heat, in their normal operating range the heat is high enough to smoke organic debris, oils, pad resins, etc, so simply smelling smoke/pad is no indicator of damage, it’s normal when the system is used hard.
The best way that I have found to adjust the rears is; find a long straight, preferably dirt road, temporarily pull the ABS fuse, have and helper spot from the edge of the road. Make an at speed pass, locking the brakes as you pass the spotter, have them observe which axle the brakes lock on first. It should be the fronts, put more rear bias and repeat until the rears lock, then back off slightly. You want the fronts to lock first, but not by much.
There was definately no fade or other problems, just the smell. I've never had that burning brake smell so it concerned me, but now that I think about it, I was running up and down logging roads all day and maybe just used them enough to cause the burning smell, but no big deal.
This was up around Nicolai Mountain, south of Westport, Oregon. Spent the day driving around and hiking old logging railroad grades. Hobby of mine.
Hah. My wife's grandparents live very near there. Nice area when it's not raining.
The smell is nothing to worry about. It is normal when you heat up the pads beyond their previous heat levels. Bedding them will help with the smell for a while.
Unless you lost some pedal you are good to go. I drive roads like those you described regularly. New rotors, 100 series pads and Dot 4 synthetic fluid will help to ensure you won't boil fluid and loose your brakes at an inopportune time.
Just a note: On my rig the combination of new rotors and 100 series pads made for a very tight fit. A little time on a random orbital sander made the fit doable.
:cheers:
I started to smell that out of nowhere a few months back. Upon further investigation I discovered that my right rear parking brake mechanism seized up at the hub from some corrosion. I needed a mallet and a punch to free it.
