Need some help here guys! A few weeks ago my 80 blew the EFI relay, lights and fuse. I did the suggested miracle wire upgrade between the relay and the fuse. Replaced the fuse and EFI relay and it started up and ran good for a few days. I was on the highway and everything blew again. Towed it to a friend of mine who is a trained Toyota mechanic. He just called me and said he checked everything (including fuel pump) and the EFI fuse still popped. He finally checked the EFI computer under/behind the glove box and said it spelled burned when he opened it up. He did some light tests to check the curcuits and if I remember correctly the light turned on when he disconnected the computer. His guess is that the miracle wire upgrade might have blow the computer. My thinking is that something had to happen short out the EFI relay & fuse in the first place. Hope this is clear enough. What do you guys think?
thanks
thanks
