Bundera broken rear diff axle
hey guys i broke the lhs diff axle yesterday and having a hard time finding a bundera wreck i noticed that the hiliux surf has the same diff so would the axle from a surf be fine to use in my bundera?
Luke
Hi All:
Luke, are you speaking of the center section (differential), or the axle shaft?
If the diff, you would need to determine whether the HiLux Surf diff is the same ratio as the diff in your Bundera.
If the axle shaft, you need to find out whether these two vehicles share the same width axles to determine whether the 'shafts are compatible.
Good luck!
Alan
the axle shaft had a looking around today couldnt find one the surf is different my diff is offset while the surf is in the middle
Fairly sure it isn't the surf but could be wrong, mate had a 1990 space can lux, he said they were the same but you had to flip the diff upside down for some reason
no year
no location
no real information
front axle rear axle
locker or no
fill it in so we can help.
