Bumper, sliders, and side pertection FINISHED
Southwest Virginia
ummm....make that "Protection"
Now all I need is a spare......anyone have a spare 315? ;)
I hope to get some pictures this weekend of them actually being used!
BIG thanks to PJ at M and M Offroad.
lol, it is for now! Wing nut WITH a lockpin :rolleyes:
Need to go digging in McMaster-Carr....
What can i say, I needed it finished by this weekend!:D
I'd like another pic from the side if possible. I'd like to see how low the bar that goes from the rear bumper to the slider sits. Also, do you think it would be a problem for people to access the rear doors?
No problem at all with the rear doors.
I have often thought of the tubing around the wheel wells like you have done. It looks great. I do have a couple of questions though?
Are there any problems with the way the frame flexes with bumpers and sliders tied together with the tubing?
If you wanted to remove a slider do work on the cats, as an example, do you have to remove the bumpers and both sliders as one unit?
I am not nocking this as I would like to do the same or weld in some tube around the wheel wells like you see on the fenders of a 40.
Buck Buchanan
Buck Buchanan
I am anticipating a little body rub with this setup, the pipes are VERY close.
I just replaced the cat with a flat unit (aftermarket) and there is enough room to replace it if needed. The O2 sensors still don't have any room :) but I plan on moving them to the air rail positions as soon as I install a York.
The pieces would need to be cut apart if any piece needed to be removed, but if that has to happen it is easy enough to put in an internal sleeve, weld, and grind smooth.
I had thought about sleeving everything and attaching it with grade 8 bolts, but I was trying for a budget build.
So far, so good....I have less than $13,000 into the truck (including buying it!)......hmmmm...I have less money into my 80 than I do in my 40!
Keith,
Are they planning on putting this out as a kit? Or even just the sliders and front/rear bumper without the tie ins?
If you don't mind me asking what was the final cost for the setup?
Glen
Keith,
Glen
PJ might, give him a call 336-909-2076. He is located in Winston-Salem NC.
Im sorry, I cant give you a price. This was the first 80 he ever built and he cut me a deal (friends, first setup, available scrap steel....) He is very reasonable and does incredible work....I really need to take pictures of the mounts for the sliders and the converter skid plate.....work of art...
Call him.
Keith
Keith,
Will the pipe around the wheel well hold the weight of the truck without leaning into the body. Could you rest the truck at an angle on them?
I'm imagining this on Rubicon or Moab or against a tree. Will it be a damage multiplier or will it save the body?
Regards
Alvaro
Keith,
Regards
Alvaro
It's DOM tubing, the same stuff that M&M uses for their rock buggies. I think the setup on my truck would protect from most any tree or rock rub. Although, if I worried about the paint, i would have them build it a little further away from the panels, mine is almost touching in a couple of spots.
The front pipe is welded to the ARB and I am considering reinforcing the "wings" on the ARB, I really think that it is the weakest link.
The plan is to build from this platform to an exo-skeleton.....one day...
Keith,
Cool, I like it.
Alvaro
what p.s.i. you running on that spare tire?:D really though your protection looks real good. i like the side protection. looks like your ready for anything.:cheers:
It's a "Run-Flat":D
Thanks, i hope to find out this weekend.....with all the rain we have had it should be interesting!
Man I am jealous...thats BA.
Keith,
I like how on the site they called yours "Project Grocery Getter", you need to wheel it and then have him submit the phots and change the name.
I will give them a call but unfortunately I have encountered a problem with my center diff -- will not lock and therfore I need to fix that first and foremost. After that is resolved then I can look into the other good stuff.
Glen
