Bulk Vacuum Hose? (+ FZ Vacuum System Diagram)
The original hose can get hard as a rock. I cut them lengthwise at the ends first using a stout sharp/new utility knife/blade (be careful it doesn't slip and cut you) then peel the hose off the pipe with a large pair of pliers, the extra leverage helps (but also be careful not to damage/crush the pipe).
That is the correct part number. Cut-to-fit.
Just out of curiosity, where does that lead to? Based on the diagram in previous post, it leads to the bimetal vacuum switching valve and that's about it. so point A to point B it goes from that valve to the throttle body? I feel like it's missing another component.
Just confirming @OGBeno's recommendation, that 95337-06020 works for 95331-06012, and you just need to cut it to length. Also, @Halfpint - the green hose inspired me! Posting this in case someone else needed the reassurance.
