@ZIFFFZJ80 any info on where to get that? I'm using some double sided adhesive and it keeps coming off!! Haha. I love it being there though. Looks clean and out of the way.
Which manufacturer? Inquiring minds would like to know.Yeah, I think I spent just over $100 and it’s held up to wind and rain like a champ.
View attachment 2314110Well here's the final list. I also installed Trailspec hood vents that I had sitting around for a while. Fingers crossed that my oil leak stops.
Replaced all vacuum hoses
Cleaned and painted valve cover
Replaced valve cover gasket
Replaced spark plug tube gaskets (6)
Resealed semicircular camshaft plugs
Cleaned throttle body and passages
Replaced both throttle body heater by-pass hoses
Replaced vacuum check valve
Replaced spark plugs
Replaced spark plug wires
Replaced throttle body gasket
Replaced small water by-pass hoses (3)
Replaced hood struts
Good to know. I can only imagine how nerve wrecking it is. I'm about to drill a tiny hole for my antenna wire and I'm freaking out about itI believe it’s the only one they sell for the 80 series. It comes with templates, but it’s still a bit nerve racking to cut a giant hole in the hood. I used an air saw. You do cut the supports in the middle. They claim the frame of the vent adds the rigidity back. The adhesive on most of my OEM supports had failed, so it was a bit flexible at first. I had to reattach everything with betaseal and it retained about 85% rigidity.
I’ll be curious about the RTT. What made you choose that oneUpgraded to a hard shell tent from Denver Outfitters over the weekend.
Also got a special delivery from South Africa - Escape gear seat covers! Pretty excited to get these installed.
