Budbuilt Shock Armor
I recently decided to put a high quality suspension on my LC, and figured that I should also add some lower shock armor to protect them.
I've had great luck with Budbuilt, so I hopped over to their website and placed an order. Land Cruiser 200 Series | Rear Shock Armor
They arrived today, and I was shocked by how stout/massive they are, so I figured I'd post a picture or two. These should get the job done.
Thank you to @Taco2Cruiser and the Budbuilt team.
Here they are with something I figure that most people have as a reference - a 12oz drink can.
How much of the shock shaft do either of these actually cover? it doesn't look like that much, and the protection is more of a ramp/skid than protecting the shaft against pitting from rocks thrown by the front wheels. On my GX with Radflo suspension I used Icon shaft shields. They were less stout and not a skid like these but they went up much higher than these appear to.
Not that one is right or wrong, just wondering if these actually provide enough shaft coverage in addition to being excellent skids and bolt protection. I can weld on extensions, just wondering if I'll need to to get enough shaft coverage.
It's a bit more than six inches on long dimension, maybe 5" of shock protection.
For @CharlieS and @grinchy, since I have both handy, here is a good comparison. Big take aways are the BB are 1/4” and TT are 3/16”, BB have more ground clearance, more coverage, and no scoop on the front to cut into dirt which also gives a way stronger front impact edge.
This is lined up eyelet time eyelet.
For protection of the shock shaft, the height of the shin guard was determined by my past experiences of where stones can pepper a shaft.
Interesting to see them side by side. Both are overkill for my needs I think . . .
I am thinking of it as insurance. A couple of hundred dollars of protection to save expensive shaft damage and rebuild costs on those shiny Kings.
I’m not a big fan of spending money to spend money. So I don’t recommend these unless you have what @CharlieS just mentioned, some expensive aftermarket aluminum shock like Kings, Icons, or BP-51s.
I came to Bud about these in the beginning of 2017 because on my first time out with my BPs, I destroyed the rubber bush of my right shock. It’s literally the lowest point on the truck and they just get beat.
If you have factory, OME, Tough Dog, or any other steel lower eyelet rear shocks... save your money. Those shocks can take a beating better.
And spend that money on fuel and time off of work to go have an adventure.
I meant the differences in design will be more than sufficient to meet my needs; not that I don't think some protection in this area is a good idea. Being as I'm crazy and drive an LX I am particularly sensitive to potential fault modes in the suspension, so yeah, a busted shock arm is bad, and depressurization even worse. Also lowest point of contact on the rig. And I have a habit of cutting it too close with turns at the rear. So oz of prevention lb of cure.
Another angle: This is an excellent time to be buying in the economy if you can, because we need to keep the economy turning over. So I have bought some stuff I was waiting on, not because I need it right now, but because I think this is the time to invest in more than a shock guard (again, if you can). Bottom up economics in practice.
So happy with my stainless BB thanks @Taco2Cruiser. Overkill yes absoulutly, and after buying a couple Icon shafts prior to install I’m just fine with buying armor instead.😉 looking forward to my BB sliders.
Installed my BudBuilt shock armor that was delivered today. Easy install & very well worth it. Top notch product! Can’t wait for my skids to arrive.
[P.S.... Spent way too long on this post zooming and correcting (like a ridiculous amount of time) but what else is there to do these days? ;)]
I like when shops talk people out of buying stuff from them because it breeds justified trust. Slee does that with 35’s (for example) and Rob does that here as well...like all the time.
But anyway...
-For those who can justify shock guards ...I gotta say that my BB shock guards have—at the very *least*—allowed me to rest more assured while wheeling aggressively...and more *likely*...have prevented real damage that would have truly sucked without them on the trail.
Honestly, I think maybe the best part of adding this kind of armor (after adding it) is that you gain the luxury of assessing its benefits **when BACK HOME & INTACT**...rather than potentially thinking about it while stuck on the trail with broken stuff, or after hobbling/bouncing back without a functional shock.
I don’t have money to burn on frivolous stuff so I do see asking the real question of whether it’s needed. There are only a few doodads on my truck that are for fun only vs. 100% useful to me. That doesn’t mean essential for someone else, but it serves a purpose that I’m happy with. I only mention that because so many trucks end up with stuff that never gets tested or pushed hard, so as folks look at different builds, trying to assess what works or what may not...it can be hard to assess. People naturally express their happiness with all sorts of mods that may...or may not...actually be effective or beneficial in reality. That’s ok too, because of just had to work that way. You can’t prove negatives, so the question hangs in the air, leaving others to hypothesize, and even leaves those using the stuff to hypothesize about whether it saved them or not.
I do feel it’s especially helpful to hear from folks pushing stuff hard when it comes to armor. So... I will say...
They are 100% useful for me...and that means FUN levels go up with them as it becomes one less deterrent to obstacle damage concerns. It’s not just about avoiding damage. It’s also about its effect on what potential hits you choose to subject your truck to on certain obstacles. So it can have a real impact on what you tackle...and what you bypass or avoid.
About cost... BB was kind to me with these as I was directly involved in testing prototypes...but...IMHO...they are worth every penny of the price and kind of a bargain in terms of armor costs and ease of install.
If you actually do bang stuff out in the boonies?...I highly recommend these BB’s. I have beat the poo out of my SS units and they’ve swatted every nasty impact away like swatting mosquitos off a buddy’s neck. :hillbilly:
Just super solid stuff holding up under my 8k# 200.
Here are a couple shots from last year at Cruise Moab... Only the post-mud hits are visible here...but there were many others beneath eventual mud.
The fact these were done in stainless meant no touch-up needed even after this nasty stuff (see below).
What you can’t see here are the hits on the upper rock guards...but they are there, under the mud layer.
Passenger...
Driver...
If you need to guard your shocks?
These things are as close to bomb-proof as we civilians can reasonably get.
Edit: Changed allowi g me to “wheel more aggressively” to... “rest more assured while wheeling aggressively.” It’s a small change but a more correct statement. ;) Aggressive wheeling can certainly happen without armor. But...armor can definitely help your truck tolerate aggressive wheeling.
[Post-P.S.... Spent way too long on this post zooming and correcting (like a ridiculous amount of time) but what else is there to do these days? ;)]
But anyway...
-For those who can justify shock guards ...I gotta say that my BB shock guards have—at the very *least*—allowed me to wheel more aggressively...and more *likely*...have prevented real damage that would have truly sucked without them on the trail.
Passenger...
Driver...View attachment 2267863
I would agree. I never thought I would have needed this kind of shock protection until I you go out and follow another land cruiser and later that day you crawl around and find out were you hit something because you did hear and feel the "chunk". The damage is done to the OEM equipment.
I had already replaced the smooshed mounting hardware for the OEM shocks and now the leading edge of the Budbuilt shock guard still make a lighter "thunk" sound because I still hit something but it rides over the obstruction a bit different.
This kind of armor is what I have installed to protect from accidental "thunks" while on the trail. I also didn't think I would have stage 4 Budbuilt armor under my cruiser but now I do. You could call it preventive maintenance. I don't plan on hitting any thing but I am glad I have well thought out and tested insurance in place.
If you see my rig around town in BZN, It just looks like a 2" lifted 200 on 33's. Most all of my add ons are under the vehicle and sliders for protection.
Thank you, Budbuilt and Rob
