Broken...something.
Kennett Square, PA
Website
cruisin4parts.com
Broken...som---EGR Stuff
When I readjusted my throttle today, I noticed a small hose out of its place. The hose end is in bad shape. Also, there's like a T-Shaped hose connector which is also rusted off. I don't know what these components are. Anyone have any idea?
(If you look at the engine of a 3FE from the front, its on the right. Middle of the engine.)
On the left circular thing, there's a broken hose below it. To the right, there's a T-Shaped Connector, rusted off from something.
Those hoses are part of the EGR system vacume hoses. Does you truck run poorly? Stutter and hesitate?
I think so. When I turn it over, the engine revs up and down as if I'm using the peddle to do it. And just a little sluggish.
So, I looked it up, yeah, definitely EGR. Now what? How do I replace that hose and that T-Shaped piece?
I got rid of my 92 FSM but if you call CDan (American Toyota) I'm sure he will be able to tell you what part the "T" is. The vacum hose is available everywhere at various prices. I replaced all the vacume hose on my old 92 and I think I used about 20 feet or so. If you replace some why not do it all was my thought. Just pull it off piece by peace, cut to size and repalce one piece at a time.
Those 2 flying saucers are the EGR valve and EGR modulator. They rot out over time and should be replaced. The diaphragms inside the EGR valve dissintegrate over time and clog the hard vacuum lines with poop. Clean out the hard lines, replace the EGR parts, replace the soft vacuum lines.
Where's the best place to get the saucers? They are definitely clogged and one's broken!
Should I get them from Toyota or AutoZone or something?
Also, Photogod
I'll buy a bunch of hose and replace the carbon filled hoses for sure! Thanks for the tip!
By the way, how much with this help my engine?
Get OEM parts. The EGR valve has a flexible metal tube that mates to the bottom coming from the exhaust manifold. Be sure to spray some penetrating oil on that fitting for a few days before attempting to separate. Metric silicone vacuum line can be purchased from www.mcmaster.com and is much less expensive than OEM. Make sure you replace ONE LINE AT A TIME to avoid mistakes. There is a vacuum diagram under the hood. Use a piece of solid 22 gauge wire and WD40 to clear out the plugged hard lines.
