I have torn down and rebuilt over a hundred t-cases, and I have NEVER seen a thrust washer fail. That is super strange Chris. Of course that doesn't help answer your question, just saying.
Logically, the thrust washer should not have any more load on it than the preload you set on the output bearings, as the output shaft and the output bearing capture the thrust washer. The thickness of the gear is nowhere near wide enough to put any load on the thrustwasher.
Were there any problems setting the preload on the bearings?
Come to think of it, I think there was a preload problem on MY Orion when I went to set it up, which was conveniently solved with the stepped thrust washers I got from Poser.
This may be the key.
Mark A.
Mark A.
