Broken down on the road - fixed with Power Wagon shock bush (!) - good to know anyway.
Opotiki,Bay of Plenty New Zealand
To the folks with manual gearboxes and other interested people
...coming back from an exciting trip on the New Zealand south island my gear shifting got suddenly worse - hard to shift between 3rd and 4th, lever seemed to be locked in the gear it was in...s*** - what's going on here ?.... I was approaching a town and pulled into a parking, stopped-though ...next thing the lever was even more locked and I was not able to shift into reverse - only 1st and 2nd left. What's that ?? Thought about a broken detent ball on one of the fork shafts... Was getting dark soon and it was not a good place to camp. So I first rang the insurance company to see if I would be eligible for a tow truck ride home. Rather expensive....it turned out and not before a automotive workshop has ruled out the issue could be fixed in town. As I always do all the work on the 60 by myself I was not keen either to have some random mechanic trying things. It was of course the weekend anyway. Than I had a brilliant idea and called an old friend who was for a time the president of the New Zealand four wheel drive association and knows a lot of people around. Turned out he knew a guy close by who might be helpful - at least could offer a good workspace. So I limped upon his invitation to his farm - and was able to pitch my RTT and have a well deserved beer.
Next morning I prepared myself to pull the top cover off the gearbox to check the situation out, It would be such a easy task if that carpet would not be held in place by the seats...ok - fnally the gear lever came off and there was the issue right in front of me: the plastic seat of the gear lever was completely detoriated and falling to bits as I pulled the lever out, some of it went straight down into the 'box. Well that was a relief - but where to find a replacement on the weekend in rural New Zealand ? A bit annoying to know that there were probably a handfull of them in old gearboxes of derelict Land Cruisers in the backyard of farms not too far away.... My very helpful host had all sorts of old vehicles - series one Land Rover - Willys Jeep - Dodge Power Wagon....some old British cars....but nothing close to the seat I needed, but he had a box full of old rubber parts including shock absorber bushes from the Dodge. The size was right and so I ground the bush in endless turns and revolutions smaller and finally fit for purpose. It worked a treat !
I safely went home which was still a days worth of driving.
At home I replaced it with the one I took out in perfect shape when I rebuilt my gearbox about 8 years ago.
What happened I believe was that I replaced my clutch prior to the trip down south. I remember that I used a grease like lubricant - in fact brake cylinder rubber lubricant on the seat when putting it back in. While doing that I thought " I should not need any lubricant here....being perfectly splash lubricated" but it was put together. Now I think that that rubber lubricant somehow reacted with the plastic material of the seat - maybe together with the Redline MT85 in there....who knows. That seat was also a aftermarket one which came in the Terrain Tamer Gearbox rebuild kit. I think it was out of one component instead of the bi-component genuine one. So - genuine or aftermarket - don't lubricate your plastic seats with rubber lubricant !
On the left of course the remains of the old one - the donor rubber - and the finished replacement.
somewhat known issue, if you had pulled up vertically on the shifter it would have shifted easily, as without the seat the shifter sinks lower and binds.
I remember a writeup, years ago, of a guy in Baja who used a piece of an old wetsuit to get him home.
atleast it is an easy fix once figured out
If I only had tried to pull the lever up...That's what I thought later too. But I was so puzzled that night that I didn't checked the easy things first.
For some reason the pic doesn't ended up in the original post - so here is it.
On the left of course the remains of the old one - the donor bush on top - and the finished replacement.
I don't know what the shifter seat is made of, but Rubber Grease absolutely can quickly degrade some plastics or rubber compounds made for petroleum environments. It actually attacks the chemical bonds.
Also, fwiw, the shifter seat in 5 spd Jeeps, with the AX15 trans, is the same.
