BritKLR's mini project - Limb Risers and/or Brush cables
Discussion in '60-Series Wagons' started by AdventureToolCompany, Jan 2, 2012.
  1. AdventureToolCompany
    1,400
    322
    Nov 6, 2006
    Boulder County, Colorado
    So I'm on my Christmas/New Year vacation and decided due to the nice weather I'd tinker with the Rhino Ride and add some Limb Risers (aka: Brush Cables, etc...).
    Reason: The trails around midwest all seem to go through the woods and the older the trail the more overgrown the vegetation. Also, last year I shredded the canvas RRT top while on the overnighter in Moab...
    Parts: Large and Small two-piece steel collars, 1/4 inch steel rod, (2) SS Turnbuckle, (2) SS rigging clips, SS 1/8 vinyl coated cable, 1/8 Cable Swags and heat shrink wrap.
    Build: I didn't want to cut, drill or weld anything to the ARB bumper or RR because of rust/structural issues. Researching MUD I found several different types/materials of Limb Risers (LR) that had been constructed, but they didn't appeal to me. So, as I researched the project I found some two-piece steel collars in a machine shop and figured they'd work nicely since they're built to hold some serious loads on a machine shaft. I took a 1/4 rod and heated and bent it into "U" shaped pieces approx. 1 1/2 inches long. Each piece got shaped to fit the collar and then welded to the collar. I used a Dremel grinder to shape the weld to make it look a little better. All the parts and allen head bolts receive a nice coat of black paint. After letting them sit for day I mounted the collars to the ARB bumper and outside edge of the RR, attached the SS turn buckles and ran the cable to the SS hooks, adjusted accordingly. Cut to length and added the Swags and covered them with heat shrink tape to finish them off.
    Result: I like them. There's enough room to lift the hood without taking them off, but if I need too it's simply a matter of loosing the turnbuckle . They're adjustable to take up the slack that will occur over time. The only thing I'd improve was to add a top rail to my RR to get the LR up higher and over the Snorkel, but then I couldn't get my 60 into my garage...so, I'll retro fit the RR at a later date and then adjust the LR to fit.
    Enjoy...Good Luck!
  2. Joe_E
    Joe_E
    3,552
    Media:
    39
    Albums:
    1
    149
    May 31, 2008
    the NJ word..
    Cool mod !
    How about some pics showing the whole set up?
  3. AdventureToolCompany
    1,400
    322
    Nov 6, 2006
    Addtional Pix
    Some other shots of the LR's.
  4. surffj62
    surffj62
    371
    2
    Dec 7, 2004
    NW of Denver
    Very nice and well built. You da man! There is some cool stuff that comes out of mud!
    The question I have is how would that keep the rtt canvas from being shredded next time? I'm thinking that making the clamp on the rack have a 8 inch high post and a similar 8 inch high post on the back and run the cable across the three points. As it is set up wouldn't it just raise the limb onto your rack? Then again, I have no experience with needing risers.
    For a post that would fit in the garage you could use the mounts that they use to put the the large antennas or out-riggers on boats. I have no idea what they are called. Round two piece, teeth that grip each other when tight and adjustable when loose.
  5. Spike Strip
    Spike Strip Torque Ain't Cheap SILVER Star
    12,829
    3,081
    Nov 22, 2005
    A Sh!thole
    Where did you find those collars ? Those would work well for high-lift/shovel holder, for me.
  6. ntsqd
    ntsqd technerd
    5,426
    285
    Apr 26, 2007
    Upper So. CA
    Search mcmaster.com for "split shaft collar"
  7. Spike Strip
    12,829
    3,081
    Nov 22, 2005
    A Sh!thole
    Perfect. Thank you.
  8. mep1811
    mep1811
    1,208
    127
    Jan 11, 2003
    El Paso, Texas
    Very nice set up. Where did oyu get the turnbuckles and snap ends? They look mych nicer than the Lowes turnbuckles.
  9. AdventureToolCompany
    1,400
    322
    Nov 6, 2006
    Good question Surf-
    I anticipate adding a top rail to the roof rack and incorporating the LR into the the new top rail. I no longer have the RTT, but I do carry my Thule box and Oztent on the roof so it's the same problem. So I'll add some type of additional riser to carry the limb over the Thule, but make it removable when not needed.
    Thanks.
  10. AdventureToolCompany
    1,400
    322
    Nov 6, 2006
  11. AdventureToolCompany
    1,400
    322
    Nov 6, 2006
    It's funny you say that....the split collars could be used to attach anything to a round tube. I got mine from a local shop, but NutsandBolts.com also has them.
    Black Oxide - Inch : NutsandBolts.com
    Good luck
  12. AdventureToolCompany
    1,400
    322
    Nov 6, 2006
    Some more shots
  13. tat2matt
    tat2matt
    1,058
    17
    Jul 27, 2009
    where the climate suits my clothes
    Very Nice!
  14. Chriedwa
    Chriedwa
    302
    May 3, 2011
    Roopville, GA
    Granted I'm new but I don't get it. What do these things actually do?
  15. GeologistFelix
    GeologistFelix
    750
    74
    Dec 28, 2010
    Vashon Island, WA
    Imagine a low-hanging branch, just higher than the leading edge of the hood and thus much lower than the roof.
    Without the brush cables, the branch is going to slide up along the hood, mash its way over the windshield wipers, then scrape all the way up the windshield, then go between the roof and roof rack, and put quite a bit of strain on the rack's front mount on that corner before either breaking or bending enough to slide along the side of the roof.
    With the cable there, the branch is going to slide along over the top of the cable, then up on top of the edge of the roof rack, then off (hopefully without smacking the roof or rear hatch very hard) at the back.
  16. Joe_E
    Joe_E
    3,552
    Media:
    39
    Albums:
    1
    149
    May 31, 2008
    the NJ word..
    They help slide tree and bush branches up and over the top.
    Edit- beaten to the punch
  17. kling-on
    kling-on Kool Arrow
    5,497
    Media:
    12
    Albums:
    1
    118
    Apr 26, 2003
    Pimpin part in SanAntonio TX
    Sweet I need those tired of trees ripping my wipers off :lol: ... Been thinking of a hoop over my lights and mounting to it ... That would also help save my RTT if I ever mount it :p
  18. Chriedwa
    Chriedwa
    302
    May 3, 2011
    Roopville, GA
    I see. Good idea/mod
  19. shotgun12321
    shotgun12321
    785
    2
    May 15, 2009
    Lakewood/Boulder, CO
    Looks fantastic. These might be added onto my mod list one day, as there's quite a few narrow trails (with trees) here in CO.
  20. cody c
    cody c
    5,035
    357
    Feb 20, 2006
    calgary
    Nice, but with the shape of the paint in that vintage of cruiser, Id be tempted to move tho front attachment points outwards to the vertical section of your ARB.
