Braking issue on my 1978 BJ40
France
I recently bought a 1978 BJ40.
It’s in great condition, except for the brakes, which weren’t working at all.
After taking them apart, I realized many parts were rusted or damaged. So, I replaced all the wheel cylinders, the master cylinder, and a few damaged hard lines. I bled the system, but on the first test drive, the vehicle pulled sharply to the left, even with light braking.
I bled the system repeatedly until I was certain there were no air bubbles left. I checked the installation of the brake shoes and springs, and everything matches the original setup. I also readjusted the shoes to ensure they were just barely touching the drums (though I might be doing it wrong, as I’m not used to dual-adjustment drum brakes). But nothing has changed, it’s still pulling left.
Has this happened to anyone else, or do you have any idea what might be wrong ?
Thanks in advance for your replies !
It’s not clear, did you replace the hoses? I have a C5500 which I had done a brake job on and immediately experienced a hard pull to the passenger side. I had a brake hose on the front passenger caliper which had failed internally. It was causing a check valve effect and no fluid could be released out of the caliper. Every time I push the brakes, it just got harder and harder on that side. From the outside, the hose looked perfectly fine.
I'm in a similar boat, they are workable but it's not great:
one of the things that has given me the most hope out of all the suggestions in that thread was to gently clamp the rear soft line with some vice grips (I carefully adjusted the tension and used a shop towel to avoid damaging the line), but the firm pedal told me that A) the air was in the rear circuit and B) it was possible to get decent brakes, I just need to keep going by changing my bleeding strategy.
I may go with the motive power bleeder, but trying a few more times w/ the two-person method. In general, crank those wheel cylinders down so tight you cannot move the wheel by hand, bleed, then back off a few clicks. they will self-clearance (and mine have, necessitating more adjustment as my pedal is too deep once again).
Hello and thanks to everyone for your replies !
I’m going to try that wheel cylinder adjustment technique for my next test run !
Regarding the other questions :
- I replaced some of the damaged front rigid brake lines, but not the flexible hoses, as they were in good condition (removed, cleaned, and tested).
- The car brakes very well but pulls to the left the moment I press the pedal.
- The pedal feels firm and sits high, I bled the system using both the two-person method and a power bleeder
I’ll keep you updated with the next test !
i missed that the brakes feel firm and pedel is good... i would adjust in the right side a click and see if that helps the pulling...
your left is either dragging more or the right is not dragging enough
are any wheels hotter to the touch then others?
Take your front drums off and look at the contact patches, see which parts of the shoe are doing the braking. Get into the drums with emery paper and brake cleaner and shoes with a wire brush and brake clean - realise you're working with asbestos and take care. The shoe diameter must match the drum, if there's meat left a brake shop can grind your drums and grind new shoes to fit
Mine did the same (test in sand to see lockup) and the right side cilinder was stuck (throw away, not to be moved by any force)
But if you have new, maybe remove the drum and see if it moves at all?
If the left drum is on then the right side cilinder should move.
Do you have the correct parts (diameter, Left front Cilinder diameter of the adjuster is 25mm, the opposite is 32mm) because I did not see (or understand) that some cilinders move top and bottom and some (in rear axle?) only top (or bottom)
So that was a dead end to try to free up the fixed side of a one side moving cilinder, used a press :bang:
You can also move the soft line from left to right to see if it changes (I replaced all because had severe cracks, inside looked fine when cut open)
Also a joke is when the front wheel drum is binding when lugnuts are tight because shoes are to tight on the drum (rotate nice but with wheel lock up)
So adjust with a screwdriver and with the wheel on, trough the 2 adjust holes.
Also bleed again in the special order?, tip from others:
Start bleeding with the driver’s front, then passenger front, then passenger rear, then drivers rear
( basically bleed backwards)
THEN reverse and bleed the right way.
