Brakes won't stop squealing!!!!!???!!
Gulf Coast
ok, I did a full rotor & pad install (f&b). Did the 100 upgrade on the f.
when I come to a stop my breaks are still squealing like they did before I changed them (you know that sound of the metal warning thread in the pads?). That sound. It only happens as I slow down to below 10 mph.
Is it because I took the shims out?
thanks!
Usually squeals are because the pins are not lubricated with brake lube, or the back of the pads don't have the shims or that brake squeal goop (technical term ;)). I applied brake lube to all moving/sliding parts and contact points (except the face of the brake pad of course). And had a thin rubbery adhesive pad for the back of the brake pads. No squealing for me.
