Fellow LC'ers,
I've developed a brake shutter that appears to be coming from the right rear. It occurs once, maybe twice then drives normal. Here are the conditions:
Another theory is that it is the parking break, but the shutter happens even when I do not use the parking brake over night Lastly, my other thought is some how the wheel cylinder is not locking the adjuster, but that is a whacked out theory.
Something tells me wheel cylinder is kaput.
Like your thoughts, thanks.
Boaf
- Start truck first thing in the morning (Drops down to 60 degrees at night). Truck is outside overnight. Use to be in the garage but no garage in New England, damn!
- Apply the brakes and feel a slam (as if the brakes finally engage) in the rear.
- After one or two stops, normal driving.
- New wheel cylinders 2 years ago, new shoes and cut drums.
- Removed drums, cleaned with brake clean, re-seated shoes (still has springs to hold shoes, hmmmmm)
- Re installed drums and adjusted brakes on both sides. No leaking fluid.
Boaf
