Brake Rotor recommendations
San Francisco
I just Picked up a 99 Mall Cruiser and I'm starting the build. I'm addressing the core functions 1st, brakes, Tires to start with. Any recommendations on brake setup? Mostly fire trail type off roading. Thank you and I hope to contribute more than I take here.
Welcome! Lots of answers on that question. Depends on your use. I mostly do daily commutes. I went with wearever rotors and will be putting wearever pro ceramic pads.
I recommend doing a little research on pad material and rotors. Different materia will yield different results.
Oem
Search will yield more varying opinions, but OEM is always a safe bet and that's the route I went when I replaced mine. Prices are pretty reasonable from places like Camelback and McGeorge Toyota.
DBA
Folks give dba’s Good reviews. I feel like I’d budget isn’t in the buying decision the dba’s are the top tier aftermarket solution
How old are the rotors? Maybe you can have them turned on the truck? You can reuse a few times before needing to replace.
Oem with oem pads and see how good the braking power. Oem rotor is about $65 at Camelbacktoyota
