Brake proportioning valve
Hello, with a 4" lift, will the proportioning valve direct more pressure to the front or rear brakes?
thanks
If you're talking about the Load Sensing Proportioning Valve (LSPV) on the rear axle, then it will direct more towards the front with a 4" lift.
If you're talking about the proportioning valve (actually combo valve) by the MC, then nothing will change when you lift it.
Fred
Thanks Fred,
I did not adjust the rear lspv in the rear after the install hoping for more front brake power for the down hill part of wheeling. my brakes dont work very well though. i have redone ft/rr and sometimes if i'm in low/1st going down a steep decline, I can barely hold it...sometimes i can't even stop it from moving a little bit. I have blead them again just to see if that's the prob.
Thanks Fred,
Do you have good pedal height or does the pedal sink more than you feel it should ?
Where do you wheel at (I'm in Tucson also).
Fred
Were the brakes like this before the lift and, I assume, larger tires ?
When you bled the brakes, did you bleed the LSPV also ?
I'm not sure of the sequence for FZJ80's, however for 4Runners (which I currently own, '95, however I'm seriously considering moving to a FJ or FZJ80 and have started looking around) it's slightly different that other vehicles.
It's
- LR
- RR
- RF
- LF
- LSPV
You may have air in the ABS system, which may take a little time to work out.
Are the brakes the same when not locked up, that is on the street ?
Again, not sure about FZJ80's, but with 4Runners the ABS is turned off when locked up (in 4WD), so any difference in behaviour may help troubleshoot the problem.
Were it me, I'd probably go on and adjust the LSPV to get some additional bias back onto the rear brakes.
In theory, when locked up, you only need braking to one wheel since there is no differential action between wheels on the same axle and between the front and rear axles.
Fred
Sounds like air in the system. It would be a good time to flush your system and get fresh juice in it if you haven't done this recently. You can also install a manual proportioning valve. I have one in my minitruck as the brakes were f'dup following lift. The manual allows you to adjust the braking as you like.
We use to run Charouleau Gap fairly often, but haven't since I sold the Jeep a little over a year ago. We normally run it from north to south, that is from Oracle, coming out on the Catalina side.
Haven' run Chivo in some time. It's gotten to be way to crowed for us (Dan, and several other friends).
There is really just a small group that I normal wheel with, having spent way to much time in groups of drunks and others who have no sense at all ;)
We did run Chimney Rock a while back to give the 4Runner a little shake down cruise. Very mild trail, but a nice little run none the less.
The 4Runner isn't set up for the Gap at the moment (31's and open all around).
I was just getting set to start the buildup on it and then something caught my eye about the FJ/FZJ 80's: solid front axle, coils on all four corners (which I'm VERY familiar with ;) ), factory lockers (diff) available on the FZJ's, etc.
This has, at least for the moment, put the work on the 4Runner on hold until I decided if I want to build it or get an '80 and start from there.
The Jeep that I had ('98 TJ) was massively built by me and, frankly, one of the best performing vehicles around and yet still used as a DD.
I had done a ton of modifications (much plasma cutting and welding).
Basically running 35's (MT/R's), 4" suspension lift + 1 1/4" bl, totally flat (to the bottom of the frame rails) tranny/xfer case skid, swap an auto tranny into it, Everything armored, raised gas tank, rear disk converision, Currie J-Arms front and rear, triangulated rear upper arms, WJ steering knuckles with the big WJ front calibers, hi-steer, full roll cage, etc.
We ran, mostly, up in the Florence area. There are some really great trails up around Florence, from "mild", like Box Canyon, to about as tough as you want (Highway to Hell, Axle Alley, etc).
Also Miners Revenge, up around Mammoth, which is one of, if not the, most favorite run of mine.
We're trying to put together a little, light run, up to Florence here in the next couple of weekends, most likely in through Box Canyon and then out through Lower Ajax.
Dan (who has a '98 TJ built up almost as much as mine was), myself, probably one of the people that I work with (Ford Ranger) and perhaps a couple of people who Dan works with (Jeeps, mostly stock I think).
Here are a few photos of the Jeep:
Lower Woodpecker (Florence area:
Miners Revenge:
Nice side shot in Upper Ajax, showing the totally flat underside:
Another Miners Revenge shot:
Upper Ajax:
I've always liked this shot. It's looking out the front window of my Jeep, just as I'm starting to enter The Graveyard (last section, optional, on Miners Revenge), looking at Al whose already in it.
Fred
Do '80's have a setup similar in the rear to 4Runners (LSPV) ?
If so, it's easy enough to adjust without adding a manual prop. valve.
Simply unhook the arm from the axle end and fasten it up higher. Some have have used an adjustable anchor bolt setup.
I simply, for now, have mine wired up all the way.
Fred
Fred, thanks a lot for the ideas. I actually didn't see the bleeder on the lspv. the brake pedal was not this spongy/soft before the new brakes. i have bled them since the new brakes and I didn't see any bubbles come out at all. I'll redo them per your suggestion again! thx
I can't believe I didn't think of raising the rear arm for the lspv...opposite of lowering it 'cause of the lift! LOL sometimes you just need another brain involved:)
Also, those are great pics. you've got bitchin lines through the rocks too and obviously your articulation speaks for itself.
Well it'd be nice to wheel with you one of these days..
Scott
Also, those are great pics. you've got *****in lines through the rocks too and obviously your articulation speaks for itself.
Scott
Scott (and/or anyone else), while I've got your attention, so to speak:
- What kind of mileage are you getting with the FZJ80 ?
- How are the 4.88's with 35's (I'm assuming that stock gearing is 4.10 or is that incorrect) ?
- In looking at FZJ's anything in particular that I should watch out for ?
I am going to start looking around at some, probably this weekend.
There's a '93 up in Phoenix that (supposedly) has the locking diffs.
Fred
i love my 4.88's with 35", (yes, 4.10's stock)it's a little lower geared than stock. the best i got was 16 but that's as light as you can possibly get on the throttle around town. that was also with 135k miles on the exhaust/both cats/muffler, and the rear canister. i now have 21/2" and a little more flow with a quiet muffler and the back canister is gone...so who knows,,if i'm really nice maybe 17. I've never heard of anyone hitting 17 though.t is
There is a great article onthis website about what to look for. just do a search. honestly, rust is a big deal as far as man hours put into tapping/cutting/breaking bolt, etc.
now i have to finish bleeding so i can get up for the Gap in the am..trailhead at 8am, Catalina if any anyone wants to join us
There is a fitting on the LSPV that can be bled. I just changed my fluids and got a of air out of the LSPV. Also check the threads on adjusting the LSPV when adding a lift. It makes a difference. T
Ahhhh, another one from Tucson.
Even though I don't have and '80 yet, still running my 4Runner, we should try and put together a run along with a couple of others that I know.
We're doing Ajax (and probably in or out through Box Canyon) today (up in Florence).
Fred
I just put an adjustable extension on Peeper's rig yesterday. It took me all of a half hour.
Basically get a piece of 1/2" steel tubing from Home Depot and cut a length off 3.5" long.
Take a 10mm x 1.25 tap and run it up inside on both ends.
Remove the the adjustable pivot assembly from the diff housing and cut off about 1/2" of the threaded part.
Leave the lower nut on and now thread the tubing onto the assembly.
Replace the assembly onto the diff housing and attach the tubing to the LSPV arm with two washers and a 10mm x 1.25 bolt.
Now you can loosen the bolt and lower nut and rotate the tubing to shorten or extend the assemble to effect brake proportioning.
Fred
I am in KC today, and my 80 is in Crested Butte. My 78 FJ-40 is in the process of being rebuilt so I would be a spectator. I would like to hook up with some folks in TUS. It sort of seems like the group here does not meet regularly. T
Hi Fred:since I like your insight even that you don'thave a 80 series yet but hope you help me to figure out a mistery that has followed me since many years ago;
3 days after I bought my brand new FZJ-80 in 1993 (4 wheel disc brake no ABS, and stock tires) I went on a short trip to test it at a mountain that surround our city about 3000 feet high. When returning to the city we were driving down quite slow because it was steep, and we made a short stop holding my foot on the brake until one of the kids finished to take a leak and got inside. After that I lost all brake power, pedal sink to the floor, pumping didn't help, and had to wait over 20 minutes until got my brakes again.
Of course my dealer didn't find any problem so I went to a friend who has a brake shop and was involved in prepping racing cars, and his answer were he suspected my brake fluid was contaminated and he flushed all my brake fluid, cleaned the system with alcohol and replace it with 600F Motul racing brake fluid.
In the mean time I called a friend at the assembly plant regarding this subject and he told me that every 3 month they send a sample of the brake fluid to Japan for recertification and he should know if there were a problem.
A week later I did the same trip to the mountain and again the problem repeated so our though was that the pads were the one to blame. So I replaced them with semi metallic pads, braking improved a little but problem remained.
A couple of months later I started the process to mod my rig with the 2" lift, 33 tires, aux tank etc and as I recall it was the first in my country to do that, there were not developed any type of caster correction kit so the tire hunting when driving fast was quite scary. Since I sourced the coils from Downey Toyota, I called them regarding this problem and they told me nobody has complained yet :hhmm: So I copied and faxed them the page of my service manual were the leading arms were showed, drawed a extension plate mod under the rear bracket to lower it and ask them what the thought about my idea. Lo and behold they developed the welded lowering bracket kit and delivered to me.
Later I ordered a set of 4 DBA slotted/drilled rotors, teflon and stainless steel braided hoses (and Carbon Metallic pads from other source) to replace the stock rotors which had then less than 300 miles.
After I installed the parts, braking feeling and stopping distance improved noticeable so I repeated the trip to the mountain several times but unfortunately once in a while I ended again without any brakes, the only good thing is that then luckily it taked less than 10 minutes to regain braking instead of 20.
Since I couldn't fix the problem as I wished I let it pass til today, taking the precaution of lower my speed when going down hill in very stepped trails.
Because my kids are older and I will retire soon, I will have enough time to retake again this puzzle and hopely fix it.
Your thoughs ?
A couple of months later I started the process to mod my rig with the 2" lift, 33 tires, aux tank etc and as I recall it was the first in my country to do that, there were not developed any type of caster correction kit so the tire hunting when driving fast was quite scary. Since I sourced the coils from Man-A-Fre, I called them regarding this problem and they told me nobody has complained yet :hhmm: So I copied and faxed them the page of my service manual were the leading arms were showed, drawed a extension plate mod under the rear bracket to lower it and ask them what the thought about my idea. Lo and behold they developed the welded lowering bracket kit and delivered to me.
Your thoughs ?
Question: When you say you pumped the brakes, did the pedal have resistance or did it go to the floor each time? T
When I pumped there was no resistance, it went all the way down each time. After waiting 20 minutes pedal was firm again and braking was fine !!!!
