Brake proportioning valve
When I pumped there was no resistance, it went all the way down each time. After waiting 20 minutes pedal was firm again and braking was fine !!!!
It sounds like your master cylinder is not returning to normal after application. I would check return spring on pedal (under the dash), malfunction in brake booster (try pushing brake pedal with engine off - what happens?), possible defective master cylinder (internal bleed through). It does not sound like the brakes, but master cylinder or booster.
My best guess would be a defective master cylinder that is leaking internally and hanging up by not returning to normal when brake is released. Possible damaged o-ring. Terry
Okay, but it happens ONLY when the brakes has been overheated by extreme braking when driving downhill offroading and never on road, and has been like this since it was brand new ( was double checked by the dealer under warranty and they could never duplicate the problem) !!!!
Once the brakes fail I just need to wait 10 minutes and everything works fine again. Pushing the pedal with the engine off allows 3 hard brakes and then of course it get harder but still stop the vehicle. Spring under the dash is fine. If the o-ring is damaged master cilinder would fail any moment I brake hard but I repeat this only happen when brakes are overheated.
I just put an adjustable extension on Peeper's rig yesterday. It took me all of a half hour.
Basically get a piece of 1/2" steel tubing from Home Depot and cut a length off 3.5" long.
Take a 10mm x 1.25 tap and run it up inside on both ends.
Remove the the adjustable pivot assembly from the diff housing and cut off about 1/2" of the threaded part.
Leave the lower nut on and now thread the tubing onto the assembly.
Replace the assembly onto the diff housing and attach the tubing to the LSPV arm with two washers and a 10mm x 1.25 bolt.
Now you can loosen the bolt and lower nut and rotate the tubing to shorten or extend the assemble to effect brake proportioning.
this works perfectly. even i could do it again if i had to. it was that simple.
