Brake proportioning valve?
I'm getting ready to install my OME 2.5" lift and I'm just wondering what I need to do to properly adjust the brake proportioning valve. Any info on this would be helpful, because I couldn't find anything specific. thanks
If you go up 2.5 inches (likely more if you had sagging stock springs) the LSPV will lighten your rear braking. This happens because the axle moves away from the body (downward) and the LSPV bar drops down.
The adjustment is to move the bar back up to simulate a load on the axle and increase braking pressure. The amount to move it up, however, has always been a test method for me. If you move it too far up your rear end will lock up early and try to pass you....not good!!!
Oh, and to adjust it you need a 14mm wrench. loosen the top nut the amount you want it to go up, then tighten the bottom to move the bar. Tighten the top back and you are done. Easy to do, so I never worked out the formula and just spent 15 min in a parking lot doing hard stops and adjusting.
two different approaches....Alky moved the arm on the threaded bolt, photo remounted the entire bracket to which everything is attached.
thanks for the info.
Do both methods work by doing simple bolt adjustments, or does moving the bracket require re-mounting the bracket. sorry bout the dumb questions. i haven't even looked under the truck for it yet. thanks again
