Brake problems
mwalls54
Cruiser Nutjob
Roanoke, VA
Well i just got threw replacing every wheel cycl and shoes and new master cycl. when pumping the brakes i bairly get any pedal build up at all. I have blead all the lines so i know i know there isn't any air in the lines.
this is the reason i replaced everything i was having to pump the brakes to stop. and the fact that brake shoes fell apart when i took the drums off.
If you have to pump the brakes to get a firm pedal, it is a sure fire sign that they need to be adjusted. Tighten the adjusters (2 per wheel) one at a time until you can't turn the wheel. Then back off 2-3 clicks until you can just turn it but it still drags.
If you still have to pump after doing what Pin-Head said to do, then your master cylinder is not pumping enough volume for your wheel cylinders. So you have to pump up the wheel cylinders by pressing the pedal more than once.
Some suppliers are pretty sloppy about giving the vendors the right stuff--they don't always pay attention to subtle differences between different Cruiser production dates. Anyway, if the M/C bore size is stamped on the outside of the old and the new M/Cs, compare them.
brakes are adjusted. factory master cylinder did the same thing as the new one. think it might be booster??
don't forget to adjust the push rod on the master... that was my issue when i had brake issues like this
it was the push rod on the servo. had to adjust it out 1/4" or so and have plenty of pedal now
