Brake Problem
New to the forums so I hope I give you guys enough info.
I have a 1993 80 I just purchased about 3 months ago. I dont know much about its history but it looks about brand new inside and out. From the looks of it it probably hasnt ever even seen dirt before.
Its lifted to accomadate 35's and has about 113,000 miles on it.
The previous owner had very little info other than the vechile was owned by a Toyota GM and all the work was done by his dealership.
With that said here is the problem... When the truck has sat for a night or more the brakes seem to have very little pressure (I cant see any leaks either) when I first start it up. I have tried to pump the brakes up before I drive but that does not help. As soon as i put it in drive the brakes have a hard time keeping the truck from moving. If im parked on a steep incline the truck CANT keep it from rolling. Once I have driven the truck for about 5 to 10 minutes they seem to work quite a bit better. They never seem to work as good as I would like but that could be because of the large tires and lift on the truck. :confused:
If you guys have any ideas I would appreciate it.
Thanks
I can stop on a dime (a big one) with 37s...it isn't the lift or the tires.
I would start by inspecting your brake fluid...should be clean and clear. If it is dark it is burnt, time for a flush and fill.
If that doesn't help, I would suspect a vacuum problem. I am more suspicious of the fluid right now, but it "could" be vacuum...which you can check by looking at the master cylinder and inspecting the vacuum line to it, and listen for any sounds at the firewall or near the cylinder that would be making "whoosh" type sounds. If the booster has a leak, the cylinder has a leak, etc you could get these symptoms.
First off, where exactly are you located, so's I can stay off of whatever roads you're driving on?? :lol:
Let us know whether:
1) The fluid level is good, and not decreasing,
2) The pedal is very *hard* to depress, or
3) The pedal is too *easy* to depress and goes to the floor.
Welcome,
Curtis
From the looks of it it probably hasnt ever even seen dirt before. Its lifted to accomadate 35's ...
Counter-intuitive but I guess that is possible. Some people will spend a lot of money on a poser truck. What size lift? Post pics if possible.
As Dan suggested, you need to look at the complete brake system. Something is seriously wrong. When you have them check it out you need to have them check the LSPV. This is a Load Sensing Proportioning Valve in the brake system. Its purpose is to bias the braking to the rear when the truck is loaded. If the LSPV was not adjusted properly when the lift was installed then it is part of the braking problem (probably NOT the only problem.)
-B-
Edit in progress...:o
Its OK Curtis. I saw your post before you edited it and you are correct, we could use some more information. How 'bout a big happy hug from ole Beo? Will that put you in a better mood? :D
-B-
Some of you guys realy make the new members feel welcome.
No the fluid is not leaking, level is holding steady. Checked whole system for leaks.
Just checked brake fluid color and it doesnt look so good. It has a light brown tint to it. Didnt think to check color. Probably should have.
The pedal pressure feels normal. Not hard or soft and remains that way. Feels like every other toyota truck I have owned or own.
I have already checked the vacumn system and everything seems normal. All hoses are conected and no abnormal noise.
Like I said, new to the forums and not exactly sure what info to give you guys. Was thinking maybe this was a common issue with these older trucks that you have dealt with a 100 times.
Tried to upload some pictures but dont know how to resize them???
Thanks
Under normal opertations i am not hitting the bump stop. When I first get in the truck and try to pump up the brakes, the pedal is not going all the way to the floor. I will check tommorow to see if it wil go all the way down and if so how easy it is. Would the pedal pressure feel any different if the fluid is bad? Visually that is the only thing I can see that could be part of the problem. Seems like a good place to start anyway.
Personally I'd start with flushing the fluid and bleeding the brakes. No telling what the fluid in the lines looks like and who knows if someone in the past simply sucked out the fluid in the reservoir and filled it with fresh or did a complete flush or ??
If you can do this yourself great, otherwise take it to someone you know/trust. A couple 32 oz bottles and some time could make a world of difference and cost wise it should be relatively cheap if you can do it yourself.
If you have someone do it for you make sure they know the correct sequence including the doing the LSP/BV last.
You may also need to bleed the MC as well but I'd start with the easy stuff and go from there.
:cheers:
I would agree with the given advise to bleed all of your calipers, the LSPV, and possibly the Master, high moisture content of old fluid or air in the lines could cause your problem. I don't have any experience with a Brake Booster failure but maybe that is the problem, FSM has a thorough checkout procedure for the booster.
Just changed all the flex lines to slee lines, really happy with the feel of these.:cool:
Couple observations. If it gets better after the truck's warmed up it has nothing to do with the fluid. The only way fluid would degrade braking is if it's got air (would not improve or change as he's noted) in the lines, or moisture (would not improve with change) in the lines. So, good advice to do, but it's not going to fix it.
The only thing I can think of that would cause these symptoms is the previous owner put some whoopdeedoo "racing" pads on the truck - perhaps trying to make up for the large loss of braking from putting the large tires on. Racing pads are very poor at generating stopping friction until they are warm from use. They're poor when cold.
So, I'd start with the cheapest solution (less than a new master cylinder anyhow) and put all new pads all around and while you're in there I'd rough up the rotor surfaces. I'd also check the LSPV which is likely at an incorrect setting due to the lift and your rear brakes are not getting as much brake force as they should. And yes, I'd replace the fluid as well but it will not do a thing for the immediate issue.
DougM
