Brake Pad Question (Re-Bedding???)
San Diego
Website
youtube.com
Hey Guys
I recently did a complete brake overhaul with the DBA rotors and the Metal Master pads.
I am not happy with the performance (all of nothing bite) of the MM pads and want to go back to stock.
My question is: Since i already bedded the new rotors with these pads, how can i install the new OEM pads with no ill effects?
I have used DBAs on 3 different cruisers with stock pads and awesome results, i shoulda gone with them from the get go.
Any advice or ideas?
Thanks
Are those pads a ceramic based pad?
I have read that when swapping from standard pads to ceramic based pads you should have the rotors turned or start with fresh rotors. I haven't read anything about going from ceramic to standard pads.
If it were me I would just pop in the new pads and bed them in properly. If you are concerned for some reason, take some sandpaper and scuff up the braking surface of the rotor a little bit.
Hey Guys
Hmmm... this sounds familiar...
Put the new OEM pads in, stomp on the brakes a few times, you'll be fine.
Thanks Ken!
Yes, i will admit: "You told me so" :D
