Brake lines
Metairie Louisiana
Do to everyday life issues i have had to put working on my 1970 (June bulid date ) FJ40. But I have been able to free up some time so now I am about to rebuild the rear end and since the axles will be out I will add the rear disc brakes. I already have the front disc conversion brake kit. I have two problems that I need to work through. The first is I still have the 9mm fittings and the second upon inspecting my brake lines I have found that they look really rough. So I am fairly sure I need to replace most of my brake lines if not all. There use to be a member on here that made brake lines but I can not find any post from him. I found 42 pages of info on brake lines but nothing about this gentleman. If any one knows if he is still making brake lines are any advice on who I should contact it would be appreciated.
Thanks Robert
In 1969, I asked my parents if I could change my name to Steve. (Most common name I could think of at the time.) Mom said, "No. I know you're having trouble with it now, but later on people will remember it."
Failed today.
Failed today.
Sorry Rainman life is throwing a few curve balls at me and some times I feel lucky to just remembered my own name. I will send you a message about my Brake line issues thanks
Great tip by Fj40jim is to use ceramic pads in the rear so there is a bit less grip ... helping to further reduce the rears as the adjustable proportional valve can only go so far
Common problem with the rear GM conversation is the too much rear braking
Experienced this in mine for sure, and like you (and Jim C.) said, an adjustable proportioning valve did not solve it. Rear would always lock up before the front in hard braking. What did solve it for me, was to replace my stock master cylinder with an non-ABS FZJ80 master cylinder. Still using the proportioning valve, but only with a slight bias to the front. Braking vastly improved with 4-wheel discs and the FZJ80 master. One of my favorite mods.
