Brake line thread pitch
Simpsonville,SC
anyone know the thread pitch for this guy?
I think M10 x 1.0
It is called a brake banjo bolt. Should be able to get them from any parts store. Typically come with new calipers.
I recently had to replace the banjo bolt. Tried all the auto parts store but didn't have anything. Had to source from the dealer. All three dealers in my area did not stock that part. II think it was ~$6.
Take the screw to a hardware store, they should have a gage to define the diameter and pitch. Be careful to remove all of the chips and crap produced while chasing the thread, that kind of stuff will ruin a hydraulic gallery pretty quick.
My problem is the threads in new caliper (see photo - Amazon sent a rusty caliper :confused:). The threads are stripped so I need to tap that.
@Karl Pollock roger that on clearing out the debris. Thanks.
Found out the pitch is definitely M10x1.0. No luck on a tap at Lowes or Ace. Any mudders in Greenville, SC have a tap I can use for 5 minutes? I don't want to wait another 2 days for Amazon. I've been downshifting and e-braking for 2 weeks now. I want my brakes back. No power slide yet, though.
Careful using a tap to clean up existing threads as you can cut new threads that will be very weak instead of repairing the existing. There are kits that are specifically "thread repair (or restoration)" kits that are essentially taps missing the first 1/2" to 3/4" of their shaft. You see the normal tap is somewhat conical shaped and for some situations where you can't run them all the way through a piece they bottom out before the full diameter section makes it into the threads.
Here's a thread restoration kit: $55
Sears.com
And here is a tap and die set: $35 (take off 20% with coupon)
SAE / Metric Tap and Die Set - 60 Piece, Alloy Steel
And here is a DIY "thread chaser" (more in line with the thread restoration kits)
Inexpensive thread chaser
Sounds like you have a fix, but in the future if you need a tap or die or any other type of metal working cutter search industrial supplies industrial hardware or production tools. Unless you really live out in the Styx you should be able to find something local. For blind holes you want a bottom style tap. For thru holes get a gun or plug style tap. I'm probably soundin preechie
Sorry, fat fingered the wrong key. I'll continue my sermon.
When tapping or chasing any thread take your time! Make sure your not cross threading, use plenty of cutting oil like wd40 or PB or Kroil. Flood the cutting area with the fluid and go.
Good luck!
