Brake lights on by themselves
colorado
I searched but didn't find anything..
so 2x now I walk out to my rig in the morning to go to work and all 3 brake lights are illuminated. I get in and depress the brake pedal and they go out... They were not on when I parked it the night before because I put new plates on it. I also get intermittent rear wiper activity. It will come on and won't turn off then just stop and work as designed. :skull::worms:
Could it be a brake light switch? Do they even have a brake light switch?!! Lol
I'm guessing a wire is grounding to frame or body or another wire. Check the sub harness that goes from one tail light to the other looking under the rear bumper. Plus in and around the taillights.
There is a brake switch on the pedal and another on the hand brake. However, that wouldn't account for the wiper.
Did ever figure this out? I'm getting the same problem.
Yes, it appears that the brake light switch is the culprit in this case. I adjusted the nut shown and that stopped the problem until I recently had to apply strong brake pressure so I suspect either further adjustment will work and if not replacing the switch is my next move. I hope that addresses your situation too.
View media item 80271
Thank you. I had a chevy switch that was brand new, it's a similar internal working design. I jumped the toyota wires to it and the brake lights worked normal. So I ordered a new switch.
