So I put in a new set of rear brake pads today. I also remover one of the rear calipers to address a rusty bolt. In the process a good bit of brake fluid drained. The brake fluid was below MIN buy not empty. I put everything back together and topped of the fluid. Brakes work great and no leaks. But my red brake light in the dash is on. Only thing I can figure is that the sensors in the brake fluid level is stuck in the low position. Maybe it didn't float back k up after I filled it?I tapped on it some but no effect. Any other ideas? What parts other than low brake fluid level will activate the red dash brake light?
job...
