So I was driving this morning and noticed that my e brake light on the dash came on, I tried depressing the ebrake handle but it didn't go away. I noticedit went away when I stopped on a red light. Anybody know whats the problem? Thanks
1: Your brake fluid reservoir is getting low. Top up with DOT-3 to the "max" line. And check your brake pads for excessive wear.
2: Your fluid reservoir sensor is bad. if your fluid is topped up and the light is still on, the dealer can sell you a new cap for the reservoir that has a new sensor in it.
Drive it again and checked the brake fluid , level was at the minimum line so probably that's the cause . I'll do the cap if the light still goes on , then pads . I just hope it's the fluids it's too darn cold here to do the rebuild on the rears . At least I'm done with the fronts though.
That's an awesome warning device that yota put on the LC, I wish they have one for a bad head gasket.
Like others have said, brake fluid doesn't get "used up". It just gets old.
You should never have to add fluid to the reservoir. If the fluid is low, then your brake pads/shoes need replacing.
With all 4 corners replaced with new pads/shoes, the fluid should be at the max line. Assuming all the parts are in good working order, you can tell how much pad life you have by simply looking at the fluid level.
In my case, all of my pads have plenty of meat, so i have to assume that there is or was a tiny leak somewhere, or that the level was marginal after the last time brake work was done.
I hear you on that, though my wrenching skills are limited to brake pads replacement and the like
But that was the last thing I did, replaced the pads (after I replaced the cap) and the next morning to work, it stopped.
