Brake issue 2022
Western Pennsylvania
Sorry if this has been brought up but no luck searching the forums.
My 2022 gx is having a brake issue where the pressure slowly bleeds off while on the pedal. No leaks and level is full/Lexus has serviced it since new and I just bought this one used in February with now 59000 miles.
I had it towed to the dealer and they will look at it Monday.
So when I was stopped at a light the gx would start to roll and I'd have to press the pedal further with the same pressure. Obviously I knew something was wrong but once I let off the pedal I had a good pedal then it would slowly get soft again. Made it work safely cause I got to pay them bills!
Lexus history shows they have flushed the brake fluid twice so either something is goofy on that end of things or maybe the master cyl is failing? I look quickly and didn't see anything dripping.
No warning light either.
Any thoughts?
Thanks
Sounds like your brakes need to be bleed. If I'm not mistaken, it's not something you can just shade tree, I think you need Toyota's Techstream software on a PC to bleed breaks.
Somebody correct me if I'm wrong.
It there's air in the system the pedal will be soft and will travel farther, but the braking level will remain consistent. A sinking pedal would be a bad master cylinder. Or maybe a slave cylinder that's leaking, but you'd see fluid leaking from it. The master can fail such that fluid does not leak to the outside, just internally.
This is how my truck was until I upgraded the brakes.
I'll find out Monday. It did feel exactly like I was bleeding the brakes as the pressure would slowly let off and the pedal would need to be pushed further. Like I said earlier I looked quickly and did not see anything leaking and the reservoir was still on the max line, doesnt mean a bleeder screw could have been letting a few drops out at a time. I didn't want to push the pedal to the floor as I really don't like missing work so I had to baby it. Lexus just did a multi point service on it in July and shows the brake fluid was flushed again as it was done at 30k also in the service history.
I have seen master cyl fail and leak into the passenger compartment.
My luck is screwed up as I bought this to not be at the dealership for repairs. LoL
My truck did this. I think it may have had the cheaper oem brake pads put on it, before I bought it. I upgraded to more aggressive pads and it has not happened again.
This affects a decent numbers of trucks with everything else being good. I personally think the oem brake pads are inadequate.
This is my thinking also of what has failed. Possibly normal out of so many I got the one that has to fail or maybe the dealer flushing the fluid caused it either by human error or something else.
Good thing will be seeing the new dealership they just opened up.
I understand brake fade, but this was clearly right out of my driveway I noticed it. So no heat build up and didn't get worse driving 14 miles. I do prefer the oems as they are more ceramic make up and less dust to my liking.
If I towed often I would look at upgrading.
Correct. It happened randomly, from cold to hot. Nothing like fade at all. More abrasive pads fixed it.
Even with positive pressure on the prake pedal.
Actually.. standard bleed works fine without TS… I flushed all of my brake fluid
So I just ran 2 quarts of DOT 4 through my system this weekend using the Motive Power Bleeder. It is slow to get fluid out the rear calipers this way. TS seems to do it faster. Anyway, braking SIGNIFICANTLY improved, and old fluid looked like crap, and I had significant pedal travel. This isn't my first go 'round with the GX brakes, however, so I'm slow to claim victory yet. However, I don't think I've ever run this much fluid through the system.
HOWEVER
I do have a question about the FSM brake bleed steps. Does anyone actually understand them completely?
It seems like you bleed the fronts with a helper on the pedal (passenger then drivers side) Then the backs using the pump with the ignition on by depressing the pedal once (passenger then drivers side). Then a stern warning that skipping the techstream bleed will surely result in killing you. Then you use TS to "bleed" the fronts back to the master cylinder 10 times per side, without opening the bleeder valve. Then use TS to bleed the rears using the pump AND opening the bleeder valves.
That seems...strange. Am I reading that right?
I have done this twice so far on my 2010. I just did old school starting at the RR finishing at FL. Did not use techstream. Worked fine. I do all the same way. Bleeder bottle (straw to the bottom of a water bottle on a magnet) to nipple, get in the car pump 10-15 (no ignition), get out, check fluid color, refill reservoir if needed, repeat until clear. Close bleeder and Progress to next farthest wheel.
  • Like
Reactions: r2m
I run motul 5.1. Its the highest level semi agnostic fluid
Motive Power Bleeder is the way to go. I've never used the Techstream procedure on my GX, and I've bled it multiple times during my ownership. I used to bleed the old-fashioned way with a helper, but the Power Bleeder is easier and quicker (especially with the Toyota master cylinder cap adapter).
I used Motive as well.. no TS and worked fine.
Fluid flow seemed fine.. IIRC.. around 10-15 psi
EDIT: I also just used the Motive when I replaced right rear caliper last year. No TS there either.
