Appreciate the input
Do you find that your rears "drip" rather than "power bleed" when using the Motive and not TS? TS will pump that junk out the rears like crazy, but it takes many minutes to purge the rears even using 15 psi on the Motive.I used Motive as well.. no TS and worked fine.
Fluid flow seemed fine.. IIRC.. around 10-15 psi
EDIT: I also just used the Motive when I replaced right rear caliper last year. No TS there either.
