Brake Inquiry
Hereford, AZ
Looking for input Guys.
I recently put new wheel cylinders & shoes on the front of my 74. Bled the line. When driving, I have a pronounced pull to the right when applying my brakes. Especially at speeds over 30. Brake hoses are newish.
Hoping for the easy fix , I adjusted the shoes on both fronts. Did not change a thing.
I know that it’s not alignment, Drives straight with hands off wheel and no brakes applied.
I assume it may be fluid pressure that is off in a Brake line? Again it only pulls when I apply brake pressure.
I welcome & appreciate any input from this knowledgeable forum. Thanks in advance!
If it is pulling to one side then the adjustment is tighter on that side. Try backing off the adjustment slightly and see if the problem still exists.
Adjust left to have similar drag as right free wheeling then road test. I think adjusting shoe/cylinder is the same. This is all Assuming also you have cylinders in correct location/orientation of course.
