Brake caliper gasket?
Oregon
Website
www.brian894x4.com
Trying to replace the front brake calipers tonight. The manual calls for a new gasket where the line comes into the caliper. I didn't see that coming. I've never seen a gasket on a caliper, usually it's just a standard brake line, but obviously the LC is different.
Any have any idea if this gasket is absolutely a one time use or can it be reused? Sure would have been nice if they could have included that with the calipers.
I reused some with no ill effect, but they are "supposed" to be one time only. The gasket is actually a brass washer.
OK thanks...interesting. Funny thing is, I'm not sure I have one on my aftermarket caliper installed by Midas for the PO. At least looking at it externally. I'll see when I pull it apart.
There are actually two gaskets/washers per caliper, one on each side of the brake line fitting. I had one or two that were "stuck" to the brake line fitting, so it may not be readily visible before you remove the brake line, but they come off with a fingernail pulling on it.
i reuse my copper washers with no problem even if new ones come with the caliper repair kit
