Brake booster options?
I bit the bullet and went OEM/Seiken. Figure its good for 20 more years.
The job was a PITA so doing it again in two years was not an option.
My sons can put in the next one.
Is there any good way to swap the booster without lifting the motor a inch or so? Anyone know?
I pulled mine out and re-installed it at least 5 times, including two separate new boosters and I never had to lift the engine, nor was I even aware that was a thing until I read some other threads about it since I was having trouble adjusting the push rod. I have a '94, which I am not sure matters, but I was able to get it in with no trouble as long as I kinda got it started into the two holes towards the driver's door and then swung it in the rest of the way. I am not sure why people have to lift the motor but I don't think the FSM calls for that, at least it doesn't in the copies I have.
When I did mine a few years ago it looked like it was not common out without moving stuff. Since I was in a well equip garage we just undid the two motor mounts and lifted a few inches.
But it was a easy option for me. This time I don't have all that. It looks like some people are pushing the rod in some to get more room. I can't remember if I needed room for the rod or the studs.
When I did mine a few years ago it looked like it was not common out without moving stuff. ...
Depends on condition of motor mounts, etc. Have worked most out without, a few have needed the motor lifted.
I have new mount. Don't know if that will make it better or worse. Probably worse.
I had new mounts as well, difficult but doable. Carefully bend brake lines and remove all the stuff, including pedal brackets, under the dash. Should work out ok...
Could be a silly question, but are brake boosters identical between LHD and RHD configurations (ie. is the position of the vacuum port the same between LHD and RHD)? I'm guessing not, otherwise one of those nice new Seiken's that CruiserYard sell would work on my 80 (which is RHD).
I am not sure if it matters. It's just a vacuum port. As long as you can get the hose on it without kinking it, I think it would work. I am pretty sure that the two boosters I bought had the port in a slightly different place and had the first one not been defective, either one would have worked. Hope that helps.
