The difference between getting the distance correct is as little as the thickness of a washer, I have had to adjust a couple that were too tight, keeping the brakes on, I first experienced this in the late 70's on a Ford Corsair.
More recently on a call out with a similar problem, I had to pull the master cylinder off the mounting bolts and slipped a washer on each of the studs, with the master bolted back in place the brakes then remained perfect for the rest of his journey. The washers a mere 1/6th of an inch.
regards
Dave
regards
Dave
