After working on my sliders yesterday I was backing the van out of the garage and had a brake line let go. It is one of the hard lines mounted on the inside of the drivers frame rail and it blew at one of the clips that holds it to the frame.
Later on today a couple friends are stopping by and we plan to replace both of the hard lines running along the frame.
I was under the 80 this morning squirting some penetrating oil on the bleeder valves to make things easier when I discovered that the bleeder on the proportioning valve is rotten to hell. That being the case do you guys think Ill be able to bleed the brakes properly just using the 4 bleeders at the calipers?
Im going to try it tonight, just wanted some input.
Thanks in advance.
D
Thanks in advance.
D
