Brake advice
Ok memebers, my brakes are shot. Coming back from Tahoe, I hear a grinding sound each time I step on the brakes. Literally grinding to a halt. I had a mechanic inspect them, looks like new pads & rotors are at a minimum. So I get a searching on this forum, looks like pads are pretty easy to replace, but rotors require more of a teardown. Then I'm reading about upgrading to a bigger caliper (93+) and 100 series pads. So here are my options:
For least expensive and least downtime:
OEM pads and rotors for an FJ80, immediate problem solved!
More expensive, more downtime: upgraded remanufactured calipers, bigger rotors, and bigger pads.
Then I've been reading that if I'm to take off the rotors, I'm half way thru a birf rebuild. So then I'm thinking I should upsize the calipers, upsize the rotors, upgrade the pads, and do the birf job. This would be the most expensive & most time consuming.
I'm looking to do the work myself thanks to all the great guides & DIY pics on this forum. But limited on time & space to do the job.
So I guess my question is if I should just fix the immediate problem and replace the pad & rotors for an FJ80, or spend a little more time & money and upgrade the caliper/pad/rotor to a 93+, or spend the most $$$ and time and throw in a birf job.
Please chime in if you've done the brake upgrade from a FJ80 to an FZJ80 and felt it's worth it or not.
btw: My truck is a '92 @ 138k miles.
TIA!!!
I only have experience with an FZJ80, but if you have the money, and don't know if/when the birfields have been serviced, I would do a full birf job at the same time. The work needed for both jobs would be pretty redundant, so it is a more efficient use of time, to do both, plus the peace of mind knowing the front end is in tip top shape for a long time to come.
Least expensive and least downtime is to just replace the pads and drive with the scored rotors until you can replace those as well. There's risks of course, I would check to see if the rotors are beyond the minimum wear rating. Brake performance will be lower until the pads wear to the shape of the rotors.
it's an 18 yr old truck, stick some pads on it and go.
Pads and go. I've driven vehicles with 1/16" grooves in the rotors for tens of thousands more miles of use. Once the new pads are properly bedded (there's a specific way to do this - research it) even an expert could not notice the braking difference.
DougM
I agree, if you are on the cheap and have no time, you can just swap in $15 pads from Kragen/NAPA/etc, and go. If you want to do it right, and you are at the point for a front end service... do new rotors/pads, rebuild the calipers, flush the brake fluid, new grease/seals for the birfs, and repack the bearings (replace if needed), and then you are good to go for a long time.
DougM
Hey Doug! Welcome back! yeah, I like your advice, will save me time & money :D Just wanted to make sure it'll be safe until I can do a full birf job & slap on new rotors.
Thanks!
Looks like the concensus is to go with just pads :) Think I will splurge a little and go with Autozone's $22 Duralast pads. They have a semi-metallic for $36 and a ceramic pad for $56. OEM is $58, but Cdan is gone until next Thur :(
Not sure which pad to get :hhmm:...any ideas?
I'm sure I sound like a broken record, but Toyota OEM brake parts would be my top choice. Harder pads mean rotor wear and often take split seconds to get up to operating temp while braking. A quarter second at 60mph = 22 feet or the difference between stopping a foot from someone's bumper and bashing them so hard you've totalled both vehicles and are being sued. And yes the lawyer will be asking you in court about the fancy brake pads you bought....
DougM
I like OEM for anything that has to do with the brakes, but since you're not replacing the worn rotors right now I guess any pads you get should do the trick. :meh:
BTW, you can talk to anyone at the parts dept. at American Toyota and just mention MUD to get the discount. They may not have the expertise of CDan or Beno but you're just ordering brake pads.
DougM
LOL! Yeah, I'd like to go OEM for all the components but trying to avoid the downtime associated with replacing the rotors and doing a complete birf rebuild. At this point it's like the shocks I replaced, anything would be better.
At a later date & place, I'll replace rotor, birf job, & pads with all OEM parts :)
