Bouncing Speedometer: HDJ81: How to Fix
Philippines
I posted this before but did not get any response.
https://forum.ih8mud.com/showpost.php?p=1715923&postcount=5
However, last weekened, the speedo started bouncing also at 80-90km mark (instead of the <60km mark I posted before). So that made me think that this problem is getting worse.
I searched this morning and looks like for the mechanical 80s (91-92), one option is to replace the speedometer cable.
Is this solution applicable to a 1990 HDJ81? If yes, can somebody let me know the part number of the cable? I'll check local dealer if this is expensive stuff. Got FSM pages: how difficult is this task?
Any other items I can do to troubleshoot/repair this issue before I replace the cable (or even buy the cable)?
Thanks and have a nice day.
Grease it...
Just for reference, if you have a later electronic speedo, you can check the CEL code. Sensor A is the speedo iteself (in the dash) and Sensor B is the pickup at the t-case.
did mine on my '91 last year @ about 97,000 miles on it . my thought on this is you might as well replace it as you still have to tear into the dashboard to try and lube the cable, which might not be the problem i.e. kinks or frays binding the cable. it is a basic :banana:under an hour fix, just be gentle with dash pieces and best to be done on a warm or sunny day helps the plastic dash pieces "bend"
:cheers:cliff
