Bottle Jack and Jack Stands Working Dimensions
Santa Fe, New Mexico
What are you using for a stock height 40, 29-inch tires? I'll be doing leaf springs, and brakes, soon I'll take the bottle jack on the trail with me as well.
I used a 3.5 ton floor jack, 4 12 ton stands on the main frame rails and at least 4 6 ton stands to drop the axles onto. The front gets tippy with no top and no rear axle, so a stand under front bumper. This was for a 4” lift.
I guess a bottle jack will work, but will have to safely boost it up to get the frame lift heights required.
Changing spring I have always used a single Jack stand. Leave three wheels on the ground. Even changing between stock and lifted spring do them one at a time. The other spring keeps the axle where it suppose to be. Both springs removed the pinion is going to rotate down. No advantage putting the whole vehicle on Jack stand unless you have a pit crew and in a big hurry.
Do cinderblocks work? How about a round of fir before it gets split down?
Oh yeah, you asked about jacks!
I use a large floor jack in my garage, big enough for my Dodge dually.
Under the seat of my 40 I have a bottle jack for the road, not sure on the size of that one.
