Booty fab steering box mount??
Mt. Vernon, WA
I'm having second thoughts about this mount that i got from Downey. I purchased it without doing much research and i'm wondering about its strength. Its made out of ductile iron and i welded the heck out of it. Anybody running a mount like this? Should i cut it off and start new?
Been running one for 5 or 6 years now. I only have 31-10.5 and am too old for real hardcore stuff. If your gonig to get crazy with the rocks I would make one from steel, put spacers into the frame and thru bolt it.
patch the frame here
It is indeed ductile cast iron and I don't buy their claims that it welds like low carbon steel. In fact, it has about 1.5-2 % carbon and it won't be ductile after welding in the heat affected zone. Depending on the cooling rate it will either be white iron (fast cooling) or grey iron (slower cooling), but both are brittle with low impact resistance (especially white iron). I don't have any personal experience with this plate, but I have seen pictures of the plate cracked off on the iron side of the weld. Try drilling across the bead into the iron and if you can't drill it, it is brittle (iron carbide).
Thanks for the advice! I obviously know little about metalurgy and have only heard things about welding cast iron, high nickel content rod, preheat, peening etc. Patching the frame where i drilled for the box is a good idea, whats orange 45?
Orangefj45 is one of Muds members.Here is a link...
https://forum.ih8mud.com/showthread.php?t=69773
Old thread but PM him and he can hook you up.
X whatever the georg count is. I used his ps plate and made some "butch built" scab plates for the side of the frame. BTW, the springs should be 27" center to center. I used the stock hangers from the rear on my SR. More photos in my sig line from the buildup. BTW, thanks peesalot for helping me thru this piece.
and you dont have to extend the frame using his plates, but another 1.5" of wheel base isnt a bad thing either. I did flip the front springs and take the frame out another 1.5. im happy with the results.
I have used this cast adapter in the past and never had a problem. I do agree there are always several ways to accomplish any project and like the orange45-style. Post up some clear pictures of some broken ones so I can see what/where it breaks.
Ductile iron
Ductile iron is very strong, stronger than mild steel for sure, but not very flexable. If the location where it is welded can flex that where the problem lies.
As you can see on Beachnuts first pic he would either have to modify an orange45 plate or move the shackle hanger.
These are some images I've found on MUD
The problem is that after welding it is no longer ductile iron in the area immediately adjacent to the bead because of rapid cooling. It is hard and brittle iron carbide (white iron), which you can see in the pictures above and it cracks right under the bead. If you could anneal the weldment by heating it to 1850 F and holding it at that temperature for a couple of hours and then cooling it slowly (50 degrees per hr), then it would be nodular or ductile iron again and it wouldn't crack.
All the good info is appreciated. I've decided to remove the old mount and am in the process of doing so right now. What i've noticed so far is the lack of weld penetration and how brittle the mount is at the weld interface! Anyways, going to fab a new one out of 3/8 plate using a template found in the tech link section as a starting point. Thanks for the asst!
Wow, I have never seen one break like that. Doesn't look like there was very good penetration anywhere but along the top, were it is easy to get to. What size tires were on that monster and what were the circumstances under which it failed?
Like everything, it's all how the work's done and how the finished product is used later.
