Boosted EGTs?
Maybe don't help .. but in diesel engines the max safe EGT 1200ºF and not for a long time .. ( pre turbo )
1500ish deg driving down the highway at 80mph on a warm day. boosts easily past 1600 climbing that grade.
but the motor seems to be doing great (200'ish) with intercooler and oil cooler
Yikes, Dusty you know I'm a worry wart but that sounds sorta high; I think that 1400 is a more desirable maximum, 1600 seems sorta high, "easily past 1600" sounds scary. JMHO. :cheers:
1650. scary by what standard? original HG and I drive her daily and lots of highway. little ricer motors go way hotter on a constant basis and my 1fzfe laughs at these silly engines
now when I post my recent catastropic spidle/hub failure you will see scary. cut it off with a die grinder
what is your temp turbo?
In my '88 turbo Supra I often saw EGT temps pushing 1750-1800 here in the AZ summer. The 7MGTE obviously isn't the same motor, but 1600-1800 seem consistent with other vehicles I have experience with.
Edit: I should note that this vehicle was running ~18 psi. If I recall correctly with the turbo putting out the stock 8 psi they were about 100 degrees cooler.
Stock gasser (non turbo) driving 60 mph on the freeway/ highway my EGT gauge reads about 1250.
The question of what "normal" S/C EGTs were came up a few years ago. At that time, i don't think anyone provided as much info as is already in this thread--so thanks :D
But I was wondering it again just this weekend. My old pyrometer died and I had just replaced it. Used the same bung, so the only difference would be a different type of probe and different meter which now goes to 2000* vs the old 1600*. The new meter reads a tad higher (maybe 50-100*) over what I was used to seeing.
On flat road pulling at about 65mph, it would typically be at 1100-1200* when I was pretty sure there was little or minimal boost being applied. When I was under load going up long hills, the highest I saw was 1575* at which point I got whimpy and laid off the pedal a bit (I figured since the old gauge only went to 1600* there was an implied max safe limit there somewhere :rolleyes:). I'd have to say on average under load I was in the 1300-1400* range, and when not under load in the 1100-1300* range.
You can see here at this pic time I was runnign about 60mph
I have no pics of my EGT before Turbo, but are far way up, like 200ºF more .. atl east.
