Bolt Torque Spec for 2F Oil Pan Bolts
From the 2F FSM...note: those values for the Oil pan x Cylinder block are in inch-pounds...that's not a lot of torque...
There are a couple of really good posts out there on tips for installing the oil pan gasket...it might be in the FAQ section, I'm not sure.
This thread might give you a good lead on finding those other threads... see posts by @John McVicker :
https://forum.ih8mud.com/threads/oil-leaks-advice-needed.821726/#post-9415743
Based on the torque values provided from the FSM in the picture above, is it a fair assumption the first number is initial torque and the second number is final torque. Example: If I’m torquing the oil pan, I first torque all fasteners to 53 inch pounds, then bring all fasteners up to 104 inch pounds?
This information from Georg is extremely thorough and useful, take this into consideration;
