Searched thru FAQs and slider threads with no satisfaction, so maybe after some good posts by existing bolt-on slider owners, this can be added to the FAQ to aid future slider owners.
For 80 owners who will be adding sliders to their armor, what if anything can be done, ahead of time, so when sliders do arrive, the installation can go smoother and trouble free? Also, try to remember back, when your sliders were new and shiny. Was there anything that comes to mind, that if you had only done that before you installed them, it would have made life easier?
Future slider owners and noobys can post specific questions and experienced slider owners and users can help them out. Since there are several varieties and manufacturers, be sure to identify the brand, model (if necessary), type of frame mount (U-bolt, backing plate and bolts, etc...) and year of your rig.
Since I'm starting this thread I'll start things out:
In the next week or two, I'm expecting mine to arrive. My rig is a '94 and I've removed the stock running boards, and reinstalled the mounting bolts in the holes to keep dirt and water out. I washed the rig and got most of the dirt off for this time of year, plus the stuff that accumulated and couldn't be reached with the running boards installed. My sliders are unique in that, no one has a set of these, yet. FOR has been developing sliders and I'll be one of the first to install them. I'll be working with Frankie for install questions or problems. The mounting method, as I understand it, will be 4 bolts and a backing plate for each mounting arm (3 per side). The USPS front mount, near the cat will have a shield to protect the cat and I'm not sure exactly how Frankie has done that, yet. On the '94s there is a heat shield on the outside, next to where running board was, that Frankie said to remove or trim. I chose to remove it. There is also a 2 piece guard that clamps around the side by side cats that could be removed. Frankie said that down there (Alabama), most take that off because stuff gets caught in there when their "boggin" and stinks to high heaven. I haven't decided if I'll remove it or not. The top half will be tricky to get out (I've tried already).
One thing that I've noticed with the running boards off is how low the cats hang. I'm glad these sliders have a cat guard, because IMHO - it's necessary. Is there anything else that I should be doing before installing the sliders?
Any and all constructive comments, suggestions or ideas are welcome.
