body dimensions
Doing a fj40 frame off restoration and looking for body dimensions, so I can square up the tub and get the bad pieces cut out, and I have a lot of bad spots to cut, any help would be appreicated, thanks, Stan
i'm tryin to find some of the same info as well...
if i come across any stuff i'll let you know.
i'm puttin 2 tubs together, so it should be a good time, ha ha
malphrus
Hodag will be pulling his '78 out shortly - as soon a we pop the top off I will try to put some measurements on line. I am in the process of buildiing a new tub out of several donor rigs so the more pics of your rebuild the better.
Let me join the club I too have a 78 40 so rusted I couldn't get any decent measurements so if any of you guys can come up with some I'd appreciate sharing the numbers :beer:
doors pillars side to side ? what's the measurements also the rear supports
etc...
I remounted the doors ,sides and top to try and get a better idea but I am still
off
thanks
I'll throw out some numbers even though they a probably not correct. Use at your own risk.
Outside width of rear tub: 64"/1625mm
Outside width of front tub: 65 1/2"1665mm
(Both of the above exclude door handles and rear side marker lights)
Width of rear door opening: 41"/1040mm
Height of rear door opening: 15 1/8"/385mm (less sure about this one)
Radius of rear quarter panel: ~6"/150mm
I'd be interested to hear if these are even close to what anyone else has come up with. I was going to use this on my tub rebuild, but I've been stalled out and haven't gotten much done.
The frame measurements that may help u are in FSM 98154, page 10-2.
