Blown Radiator
San Diego
Not sure where it blew, just went to the car wash and when I parked at home my front end was a waterfall. The leak isn't up top to my surprise it looks to be right in front of the fan in the aluminum. Im currently looking into a local Aluminum radiator Alum radiator 91 to 97 land cruiser and transmission cooler. Any opinions or ideas to why the radiator blew in such a weird spot? Or is that normal? My 4runners would always crack uptop. Hope its just the radiator and nothing too crazy
Depends on the mileage and how it was driven. I have to replace my friend's tomorrow and his did the same thing. I have had good luck getting them on ebay for $95 so it shouldn't be that big a deal to replace.
What year are you doing, I have a 93 and can't find anything under 250
Tons of info on radiators on this board. Do some searching for 'Koyo Radiator'. The Koyo seems to be the one to get if you don't go with Mr. T. I wouldnt put a $95 ebay radiator in my rig, but that's just me. Might want to think about rebuilding the fan clutch too. Do a search and you will have hours of reading material.
The OEM radiator for 95-97 is about $385. It was an exact drop-in fit and engineered to work.
JMO.
Mine split the top tank wide open.
Good Luck!
That guy is selling a "cheap" eBay radiator. It's been for sale for months. I wouldn't buy. Get a Koyo if you're strapped for cash. If you can afford it, get the OEM! $304 from this dealer: Radiator - Toyota (16400-66040)
Why it blew is another story. Either it was old and ready to go... or worst case scenario you have exhaust gasses getting past the head gasket and into the coolant jackets (blown head gasket). If you have a leak down tester, you could test to see if air is getting into cooling system. Or I think there are those chemical kits now that detect CO2 and are easier to use.
IMHO get a Koyo, they are exact fit too. While you're at it replace the water pump, thermostat and all of the hoses. They are easy to get to with the radiator out. Don't forget Red antifreeze and distilled water! I installed a Koyo a couple of years ago and never looked back.
Ned
If you have not already done you oil pump and front main seal, NOW's the time to do that too....while the radiator is out.
Oh yeah and:
Dizzy O-Ring
Valve cover gasket
Spark Plug tube seals
PCV grommet
vacuum hoses
Power steering hoses
Water pump
AC and WP belts
Alternator upgrade
2nd battery
Winch
Blue Sea Fuse Block
Driving/Offroad lights
Front Winch bumper
Suspension lift
TRE
Front axle rebuild
New brakes, rotors
New tires
Etc.........
Everything above the space is serious.
How did it end up going for you?
Ned
Is the TYC 1918 the same and if so will it fit my 1993? Ive read that koyo and TYC are the same but my real question is; are the 1993-94 radiators the same as 95-97?
Any opinion of that radiator I have in the link? Im not sure if I wanna go with it anymore...
Oh yeah and:
Dizzy O-Ring
Valve cover gasket
PCV grommet
vacuum hoses
Water pump
AC and WP belts
Alternator upgrade
2nd battery
Winch
Blue Sea Fuse Block
Front Winch bumper
Suspension lift
TRE
Front axle rebuild
New brakes, rotors
New tires
Etc.........
I got the front gasket seal and the oil pump seal... along with the new screws (not sure if new screws were needed) will be doing it this weekend, I have a new valve cover... will look into new belts, and power steering hoses, and redoing alot of the general hoses while Im in the engine bay...
There are a ton of threads on this subject, but most Mud members will agree, go with the factory Toyota radiator. Yes it will cost you more up front, but there are more then a few members here who have gotten over 20 years of use out of their original factory radiator before needing replacement, and that's saying ALOT about Toyota quality.
I'm a fan of modding the fan clutch too. If it were me, a "while you're in there" would be to send off an oil sample to Blackstone. It's cheap and worth the peace of mind to know if you have any HG issue.
I bought the CSF 2517 brass/copper radiator. It isn't cheap but built very well and fit perfectly.
Hmmm will have to invest later, I'm looking for something under 200, I decided to take some summer school organic chem classes and don't have much to spend... was looking into the TYC:Koyo brand one. Saw mixed reviews but as long as it lasts me a few years I'm good to go!
Had my mechanic check everything out and he did the blackstone and everything looks good to him which means it looks perfect to me haha. I guess after 260k the OEM radiator gave out. True workmanship by Toyota for having their product last almost 24 years!
I got a Koyo from 1-800-radiator. The first one I got leaked out of the clamps, the second they sent me has held up so far. Ymmv
Funny, I just posted on this thread and my original radiator is now leaking from the gasket on the top tank. I dropped it off at a local radiator place and Im going to try and have it rebuilt. They said it would depend on the plastic and the aluminum fingers. I'll post my findings later this afternoon.
