Hello All,
Had a no-start situation last week with my '91 TLC. Cranks strong, just won't start.
In the past, the EFI relay is usually the culprit. Replaced it with oem, still wouldn't start...no spark at coil.
Found out that the 7.5amp fuse was blown. Replaced it and it started and ran fine until the next time I went to start the truck.
This is repeated again and again.
I can tell if the truck is not going to start, because the dash warning lights will not illuminate as I turn the key.
Looked at the wiring underneath dash & behind fuse panel to see if there was any grounding out and saw nothing unusual.
I was thinking that it's the ignition switch.
I have the shop manual and there is nothing that helps troubleshoot the ignition switch.
Any help is appreciated.
Marco
Marco
