Blower problems
ygthb
MUD Addict
Kyle, TX
My blower had gotten noisy, but was still working. Figured it was leaves. Got it pulled yesterday, OMG
Straange looking debris. What is it?
foil backed insulation, not sure where from
Just a question, but do you by chance live next to an Alcoa Aluminum foil plant????? That first question was just a joke, but here's what i think that's from, I seem to remember some of the evaporator boxes have this type of aluminum/fiberglass insulation on them to help with cooling.
The truck has been mine for a few years, in Kyle Tx. PO was in San Antonio. I just want that sweet, sweet AC here in central TX. Believe it or not it was still moving air, not much, but it was moving.
I think that aluminum/fiberglass insulation came from inside your AC evaporator box, it's used as insulation around the evaporator coil. With age it just got weak, flaked off, and ended up inside your blower fan.
Is there a disadvantage to not having it in place?
That insulation is in place to help protect the evaporator coil from outside heat sources, and to help keep the coil as cold as possible. If that insulation is not there, then the coil will not work as efficiently as Toyota designed it to.
Next project, insulation. this list is long
I have to forewarn you, taking that whole dash out to get to the evaporator coil is a BIG job, so plan on making a day of it. Oh ya, if you don't already own a copy of the factory service manual, i highly recommend you get a copy BEFORE you start this project. One last thing, while your that deep into it make sure to check out your heater core for signs of leaking while your there.
