Block Heater
Good question - I've been looking at a tank type heater myself, after hearing people having problems with the leaking freeze plug style like you're looking at.
Amazon.com: Kats 13150 1500 Watt Aluminum Circulating Tank Heater: Automotive
My thought is that if the tank type heater goes bad, it should be easy enough to bypass it with a simple hose splice. A freeze plug style would require you to have to install a new freeze plug (which isn't bad, if you can get at it easily). From a little research on here, a lot of people are installing the freeze plug style on the exhaust (USPS) side of the block, though I believe they're intended to be installed on the driver's side. The driver's side looks like it would be a lot more difficult to install to me.
I've been thinking about that exact style tank type too. 1500w is a ton of current, so I'd probably go for the 1000w model to keep the draw under 10 amps. It seems like a more difficult install than a freeze plug type. It also uses much more electricity; but if it heats up 2-3 times quicker it's a wash. It needs to sit lower than the engine for the siphon feed. Would the best hose routing use some type of 5/8" hose nipple that threads into the block drain and return to one of the heater hoses? I assume you couldn't get full circulation through the system with the thermostat closed.
I just used a micrometer to check the Toyota Canada block heater I have. It is waiting to be installed... Anyway, the part that is inserted into the freeze plug hole, is 34.75mm, the lip/flange that sits outside the block is 37.90mm
A search on block heaters will give you some threads were the Toyota block heater is pictured.
Not identical to the Toy CA model (it is in its original package), but it looks like it ought to work, this coming from someone who has yet to install one... so take it for what it's worth :D
