blinker no blinky
high desert, ca
Recently a post smashed up some stuff on my fj55, like the turn signal on the front. I could never find a replacement for a 68' horizontal style, so I hammered and bent mine back in enough shape to accept a light bulb again. Hopefully temporarily, I rigged up a running light lense from a 72 fj55 on there. Now the blinkers on that side do not blink, instead they are continuosly on when the turn signal indicator lever is moved. Is this just a problem with a short now, or improper grounding, or can smashing light bulbs hurt your flasher. The blinker only has a one wire hookup, so I assume the ground is to the fender/signal junction. Whatcha think, what causes a non blinking blinker after damage?
agree with poser, sounds like a poor ground. The bulb socket inself is the path to ground and the power is applied to the bulb through the center connector. Measure the resistance from the socket that holds the bulb to the negative battery term. it should be pretty close to 0 ohms, maybe as high as 100 ohms but the closer to 0 the better. If it is not close to zero check the blot that mounts the turn signal to the fender and make sure it is makeing good cantact and is tight.
Hope that helps.
If you wanna know if you're barking up the right tree chasing a ground issue, just run a jump wire from a steel part of the housing directly to a clean frame ground and see if anything changes! ;)
There has been a lot poste here on this topic in thepast month, so a search would be informative. The basic problem is that the turn signal circuit isn't drawing enough current to trip the flasher. There is too much resistance somewhere and it could be any connection or wire or even the wrong bulb.
If both sides won't flash, it is pbobably a bad connection from the fuse block to the switch; if it is one side in is a probably a bad connection after the switch. Grounds are notorious problems and easily trouble shooted by jumping the hosing to ground as Mark described.
