Blinker issue?
I do still have my AHC, so I don’t think it’s that
i just hooked it up to a trailer and the problem translated to the trailer. Only my right blinker works. Left does nothing. Hazards don’t work either on the trailer.
Any idea how I can just remove the aftermarket wiring to see if thats causing it?
Yeah you can just remove the wire taps. Will need something to cover the slight holes in the OE wiring insulation. Liquid electrical tape would probably be best.
I'd try wiggling all those connections while the blinker is engaged to see if that's changes/corrects the condition.
That factory connector those wires are hooked to might be for a OE 7-pin trailer wiring setup? I looked into all this a while back but don't remember what all the various options were.
It’s for a 4 way. I still haven’t gotten to the bottom of it…..
Did you remove that converter box?
Yes, and it seems to have fixed my blinker/ hazard issue…. But that’s gone away before and come back. So I can’t say for certain. But still no break lights and can’t get out of park
Did you check your Blinker Fluid?
Might be a little low...
Sorry, but I couldn't resist.
Felt a smart @ss comment was needed :)
Good luck with fixing the issue.
Tom
Solved: Looks like my fuse block has gone bad. My guess is that trailer wiring fried the circuit or whatever it was feed on g back to.
Which fuse block? Got pics of the destruction??
